Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Murphy 74 (guest)
Guest
Posts: n/a
Get cel code p0342 inlet phase reference could this just be inlet cam sensor?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-09-2017, 06:55 AM
Nick at Pelican Parts's Avatar
Yes, most likely just the sensor. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Depending on the MINI FC code, this is what that P code indicates:
P0342 0x2983 Camshaft Position Sensor 'A' Circuit Low (Bank 1)
P0342 0x300D Intake camshaft position sensor: Signal too low
You can test your sensor before replacing it to be sure. Use this article: MINI Cooper R56 Camshaft Position Sensor Testing (2007-2011) | Pelican Parts DIY Maintenance Article.
Old 05-12-2017, 09:28 AM
