Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
joe highway (guest)
Guest
Posts: n/a
Re: Clutch Replacement.
Pretty good directions that is up and until I attempted to remove the transmission. Try as you might, it is impossible to remove the transmission without also dropping the sub frame and there were no directions for that here. Took a bit of thought and injenuity, but its done! Oh, mine is a 2007 56R. Please update article and it would be great.
This post was auto-generated based upon a question asked on our tech article page here: Mini R56 Clutch Replacement | R56 Cooper (2007-2013) | Pelican Parts DIY Maintenance Article
Old 05-24-2017, 08:11 AM
Nick at Pelican Parts's Avatar
Figure 10 notes to remove it.
Remove the drive axles. See our tech article on drive axle removing. Remove subframe. See our tech article on subframe removing.
Large Image | Extra-Large Image
- Nick
