Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Ray (guest)
Guest
Posts: n/a
I like your description of how to remove hoses. I have 2005 mini S, big leak in the system. Pouring r water or fluid into reservoir w car off....drips onto ground. How do I find source of hose leak?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Radiator, Thermostat and Hose Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 06-26-2017, 11:20 AM
Nick at Pelican Parts's Avatar
You will need to either inspect the area of the leak visually. or use a pressure tester to force the leak to occur.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Pressure testers here if needed: Pressure Testers - PelicanParts.com.
Old 06-28-2017, 09:15 AM
