Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Administrator
Luccia at Pelican Parts's Avatar
How Many Miles Are On Your MINI?
Our in-house R53 has been well kept for since day one, so the mileage does not reflect its year. We are around 50k on this MINI Cooper S, no engine replacement - all original.
Post up yours below with how many miles are on the chassis and if you've ever had any major engine work done.
Old 07-18-2017, 09:43 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
60K. Several thermostat housings, several oil pump solenoids.
--DD
Old 07-18-2017, 02:29 PM
2002 R53 original owner "238,400 miles with smiles. Replaced suspension bushings 2X, struts, clutch, power steering pump, supercharger (at 200,000), starter, a/c compressor, 8 sets of tires, 1. Set of rotors, tie rods, ball joints, 3 sets of pads, slave and master cylinder....and other bits and pieces. I do my own work, and I keep Pelican staff busy. MINls are realitivly easy and fun to work on.she still look good for her age!
Old 07-21-2017, 03:00 AM
Administrator
Glad we could help keep your R53 on the road. She's a beaut! Thanks for sharing.
Old 07-21-2017, 11:36 AM
Bulletproof MINIs
This is Alice I and Alice II. Both are '05 R53s and built only a couple weeks apart by VIN. I took #1 to 329,000 miles before picking up #2 which is at 160,000 this week. Both have gotten new solid harmonic dampeners and alternators while #1 also got a new clutch at 200,000 since the throwout bearing gave up, new wheel bearing, LCA bushings, fuel pump, several idler pulleys, power steering pump (after several clean-outs that added 100,000 miles), O2 sensors, slave cylinder, thermostat, and Koni shocks as well as too many tires to count. She also got a new valve spring when an over-rev broke one. #1 got Mobil 1 but #2 is getting Royal Purple to compare cam wear. Both still run strong.
Old 07-24-2017, 07:40 AM
