Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
shadowfax22 (guest)
Guest
Posts: n/a
hello again
so i connect diagnostic when the car was on and i get fault code : Coding is not ok
High Voltage High Pressure Fuel Injector Cyl. 4
High Voltage High Pressure Fuel Injector Cyl. 3
High Voltage High Pressure Fuel Injector Cyl. 2
High Voltage High Pressure Fuel Injector Cyl. 1
Central body - FRM Legroom Module
Chassis sensor signal, front short circuit
Central Body - JBE Coupling Box
that's are all diagnostic faultis
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Crankshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-25-2017, 06:51 AM
Nick at Pelican Parts's Avatar
Sounds like a short in the fuel injector harness.
- Nick
Shadowfax22 (guest)
Guest
Posts: n/a
Dont have faulty codes, i will check al that you recommend!
Hope to figure it out whats wrong.
let me know what you find.
- Nick
