Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Adam (guest)
Guest
Posts: n/a
Hello, I replaced the part of the brake switch where the plug connects to the four pins. I did not replace the part that seats into the metal bracket as it was too hard to remove. Is that part that goes into the metal bracket required to be replaced, to work with the other part of the assembly? My brake lights still stays on when the car was turned off.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Brake Light witch and Clutch Switch Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-08-2017, 07:12 AM
Nick at Pelican Parts's Avatar
Yes, the part in the metal bracket has teeth that grab the adjustment splines on the new switch. I would replace it.
- Nick
Brake Light Switch
I will do that since it is what you suggested.
Can you explain to me how the brake light switch works? I ask because I don't see any mechanical interface other than those splines, and then it just looks like a 4 pin connector. Is there some magnetic going on, interfacing with those splines or pressure sensor somewhere? It would be very helpful to understand. Thanks!
Old 09-08-2017, 07:20 AM
