Guest
Posts: n/a
I�ve got an 09mcs that is reading 1100psi on the fuel rail at idle. I only have a code for too rich at idle and too lean off idle. What would cause my pressure to be so high? Could a failing pressure sensor do that without setting a code?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Rail Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
How are you reading pressure? Can you share a photo of the reading?
- Nick |
