Originally Posted by targa911S View Post
Good for you Jeff and spread the word. Spring traps will do the job on rats and mice. Humane traps will work for the ground squirrels and then just kill them in the trap.
We had a 4 foot snake die in our back yard. It was acting very sluggish and had a bulge in it's so it looked like it had eaten. I suspect it was a poison rat or critter it ate. I had to bury it under our compost pile.
Old 08-02-2018, 10:25 AM
Craig T's Avatar
LOL...Have you considered decaf ?
HA! Yeah, and I shoot straighter when I'm not having caffeine tremors.
Craig T
Old 08-02-2018, 11:38 AM
Make Bruins Great Again
Por_sha911's Avatar
Joe
Old 08-04-2018, 02:39 PM
bmcuscgr94's Avatar
My next project is to get rid of 5-6 ground squirrel burrows. I've got a loaner Rodentator I'm going to try and see what happens. The varmints are starting to chew holes in our 1" PVC irrigation lines, never done that in the 30 plus years I've been around here helping. I'm tired of having to dig down 5-6 feet to patch the leaks.
Old 08-04-2018, 05:13 PM
Control Group
Tobra's Avatar
For that sort of job, in an orchard, Jack Russel Terrier maybe?
Old 08-04-2018, 05:42 PM
bmcuscgr94's Avatar
That maybe Plan B. the Rottweiler hasn't been successful so far this year.
Old 08-04-2018, 05:45 PM
least common denominator
scottmandue's Avatar
Originally Posted by Jeff Higgins View Post
Your only real choice to get rid of them is poisoning. You just won't be able to shoot enough of them to truly rid yourself of these pests.
Oh yeah?
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 08-04-2018, 06:07 PM
bmcuscgr94's Avatar
UPDATE: To close the loop on this. Used the rodentator on about 20 burrows (found lots more than expected) with about a 50% kill rate based on return squirrel activity. However, due to complaints about the noise from the neighbors, I only used it about three days before quitting. I need to wait until the three neighboring wineries are all having events that may drown out the booms.
Old 04-09-2019, 06:56 AM
Rickysa's Avatar
Had to do a search...kinda looks like fun (if only Bill Murray had one )
rodentator:
Rick
'89 Targa
Old 04-09-2019, 07:36 AM
What about dry ice? The CO2 will sink down into the burrows and kill them? Better than poison if it works.
In CA I just use CO. Worked for about 5-6 months at a time.
Brent
Old 04-09-2019, 07:37 AM
I wonder what the next season's result is with the rodenator? Soil loosened up..around here, they would be back in full force.
I have the best results with the step-in traps. At the first sign on raised tunnels..I set 3 or 4 traps and catch the dirty B right away. It's amazing how much damage one mole can do.
If its a gopher...the milk jug w/water works every time.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 04-09-2019, 07:50 AM
Control Group
Tobra's Avatar
Dry ice is quite effective for ground squirrels, though it may not work on the levee, too many points of egress that are lower than where you put it in the hole.
Old 04-09-2019, 07:51 AM
bmcuscgr94's Avatar
Neighbor just hired a guy who uses a CO2 device that injects it into the hole with some pressure. I'm waiting to see how that goes.
Old 04-09-2019, 07:53 AM
bmcuscgr94's Avatar
rodentator:
It's a blast (pun intended). I did have to watch out though, it sometimes shot flame back out of the hole.
Old 04-09-2019, 07:55 AM
One supposed advantage of the Rodenator is it collapses (at least partially) the tunnels preventing the animals from repopulating them immediately. I'm trying to make a home made one, but it's on hold right now because I have other things in the works. The main problem seems to be getting the gas mixture right.
Marv Evans
'69 911E
Old 04-09-2019, 08:04 AM
bmcuscgr94's Avatar
getting the gas mixture right with the rodentator is by trial and error after you set them as per the instructions. You adjust the mixture with the torch handle on the older model I'm using.
Old 04-09-2019, 08:09 AM
I was using a tip with an open propane outlet and trying to adjust the mixture with the knob. I've replaced the open tip on the gas tube with one with a propane orifice, so when I try it next I'll see how that works out. What were the instruction from Rodenator for the initial settings? Thanks for the input.
Marv Evans
'69 911E
Old 04-09-2019, 08:23 AM
bmcuscgr94's Avatar
I need to pull out the sheet to be sure but IIRC is was 3/4 turn on with the propane and 1/4 turn with oxygen
Old 04-09-2019, 08:33 AM
Thanks. The propane side must have a nozzle with a propane orifice on the Rodinator you used. Usually the oxygen supply side, especially if it's compressed air, is open several times the amount of the propane side.
Marv Evans
'69 911E
Old 04-09-2019, 10:21 AM
bmcuscgr94's Avatar
I'll find the instructions for the exact specifications. Everything gets mixed together in the tip assembly as it's injected into the burrow on the rodentator which also has the ignitor. Once the mixture is set, you inject it into the burrow for a set amount of time, close off the valve to prevent back flash and hit the ignitor
Old 04-09-2019, 10:35 AM
