pwd72s's Avatar
Mazda's engine development
Sounds weird to me...kind of a gas engine, but semi diesel design?
https://www.caranddriver.com/reviews/2019-mazda-3-with-skyactiv-x-compression-ignition-gas-engine-prototype-drive-review
Old 07-30-2018, 09:22 AM
Engineering explained always does a good job braking down new car tech. "lean burning" gasoline engines has been one of those techs that have been pursued forever. It seems mazda has commercialized it for at least part of the engines operating conditions
https://www.youtube.com/watch?v=yNSxow3W7ek
07 Exige S
Old 07-30-2018, 11:03 AM
Not a new concept, but Mazda seems to be able to make it work commercially.
Brent
Old 07-30-2018, 11:06 AM
Unregistered
sammyg2's Avatar
A friend of mine had one of those in high school. Darned thing would ping like crazy every time he pushed on the gas.
Took 30 seconds to shut down after he turned off the key too!
Old 07-30-2018, 11:31 AM
The Stick
RKDinOKC's Avatar
Mazda goes mmmmmmmmmmm
They have been calling their variable cam timing SkyActive for some time now.
My general description is it's load based variable cam timing with mixture and ignition to match.
Friend as a year old Mazda 3. It does pretty well. Seems to have plenty of power when needed and gets great gas mileage cruising.
Richard aka "The Stick"
06 Cayenne S Titanium Edition
Old 07-30-2018, 11:40 AM
canna change law physics
red-beard's Avatar
Ford is doing an Achates opposed Piston engine. The plan is to make a 2.7l engine with 42-45% thermal efficiency. This will mean mileage in the 40+ mpg range with a Ford F150, on gasoline.
James
Red-beard for President, 2020
Old 07-30-2018, 02:56 PM
I'm with Bill
Jims5543's Avatar
A lot of the articles refrain from speculating on gas mileage, I think I read to expect Prius type of gas mileage, like 50+ MPG with 60 MPG not out of the question.
If they hit that mark it will be a game changer.
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 07-30-2018, 03:00 PM
Did you get the memo?
onewhippedpuppy's Avatar
30% improvement would be pretty substantial. Mazda is such a cool company, the smallest of the Japanese manufacturers but possibly the most innovative.
‘07 Mazda RX8-8
Old 07-30-2018, 05:07 PM
Variable compression, right?
1972 911T/S MFI Survivor
Old 07-30-2018, 06:12 PM
Control Group
Tobra's Avatar
45% thermal efficiency?
Old 07-30-2018, 10:57 PM
Arizona_928's Avatar
Almost like a common rail.
I like
dolor et pavor
Copyright
Old 07-30-2018, 11:00 PM
Ooo? What’s the timeline on that. I’ve been saying I want an f150 sometime in the next 5 years....
Old 07-31-2018, 12:31 AM
Carnot Cycle! About the only thing I remember from my ME classes.
‘07 Mazda RX8-8
Old 07-31-2018, 05:46 AM
White and Nerdy
Tervuren's Avatar
The article did not mention variable mechanical compression.
However it using an explosion of richer fuel/air near the spark plug to further compress the leaner fuel/air that was taken in during the intake stroke.
Old 07-31-2018, 06:11 AM
(the shotguns)
berettafan's Avatar
so I read the first few paragraphs and I'm not clear on what's new here?
mazda wanted to use compression only to ignite an ultra lean fuel/air mixture but it wouldn't work so they brilliantly introduced spark to the mixture and boom, skyactiv x!
Old 07-31-2018, 06:22 AM
I think Infiniti has come out with a variable compression engine, also a cool idea.
It's both a compression and spark ignition engine, and goes between the two modes depending on load. Best of both worlds between a diesel and gas engine, but using gas and at a cost comparable to a standard gas engine.
‘07 Mazda RX8-8
Old 07-31-2018, 06:25 AM
White and Nerdy
Tervuren's Avatar
Think of it like a thermonuclear bomb.
A fission bomb creates the environment for a fusion bomb to go off.
The combustion chamber has a fuel/air ratio for compression ignition.
A precise second direct injection fuel pulse creates a small area near the spark plug that fires off like a conventional gasoline engine, this explosion raises the compression of the remaining leaner fuel/air in the cylinder and allows it to combust from compression rather than ignition spark.
Did that make sense?
Old 07-31-2018, 07:14 AM
(the shotguns)
berettafan's Avatar
yes. we had fuel and air in the cylinder as it compressed but it wasn't going to ignite under just the pressure so we injected more fuel and added a spark.
it this really a variable compression engine now?
Old 07-31-2018, 07:23 AM
White and Nerdy
Tervuren's Avatar
That is like asking if a thermonuclear bomb does not have a fusion reaction.
It is a dynamic variable compression in that the compression required to light off the majority of the chamber is higher than the fixed compression ratio of the piston motion.
Reaction one is used to create the conditions for reaction two.
Old 07-31-2018, 07:28 AM
White and Nerdy
Tervuren's Avatar
One more attempt in case that doesn't stick.
In the conventional engine the spark creates a higher temperature as the source of ignition, heat radiation is how the reaction spreads through the combustion chamber.
In this Mazda engine a small reaction in the combustion chamber creates an increase in pressure, and compression is how the remaining fuel/air mixture burns.
So in the conventional engine it is heat radiation for ignition at a given compression.
In this Mazda engine it is heat radiation with a small part of the chamber in fuel air mixture ratio 1 that is ignited. This combustion expansion changes the compression ratio for fuel air ratio 2 that fills the remaining area of the chamber. This change in compression ignites fuel air ratio 2.
So the part of the chamber at fuel air 1 ignites by heat at compression level A, the part of the chamber at fuel air 2 ignites by increased compression to compression level B.
The compression ratio for ignition of fuel air 2 is higher than that of fuel air 1.
Fuel air mixture 1's combustion is used to control the compression of fuel air mixture 2.
If you spray food coloring into water, there is time for it to dissipate to median levels.
The second injection of fuel does not have time to mix with the remaining part of the chamber.
This results in two different fuel/air ratios in the chamber at the same time, one of which is used to raise the compression of the other.
Old 07-31-2018, 07:41 AM
