If they lost that much weight overnight, they were some pretty ****ty potatoes...
I suspect foul play, or a herd of raccoons. |
Platinum Member
What is their new weight?
99 lb.
Cure for TDS - before believing sensational headlines, read the articles and do a little fact checking. |
canna change law physics
typo, yes, 49lbs, so 50 lbs water loss
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I'm with Bill
That was my initial thought as well without working out much more than they lost 1% of their water volume and they are 98% water so 1% = 0.99 lbs.
Am I missing something here?
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
That's 98.98% water. (98 divided by 99) To get to 98% water you need 1 lb of potato and 49 lbs of water... (49 divided by 50)
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
I'm with Bill
I read it this way.
The mathematical potatoes, which are not actual potatoes, are composed of 99% water. When left out overnight they were then composed of 98% water or 1% less water then the day before. 1% of 99% = 0.99 rounding off.
The first part is correct. The math after that is not. That method would work if the mass of the potato changed also.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 08-17-2018 at 01:42 PM.. |
evening
water / (water + solids) = .99 water + solids = 100 lbs Solids = 1 lb water = 99 lbs Morning Assumption solids are conserved (1st low of Idahodynamics) Solids =1 lb Water + solids = ? water/(water+solids) = .98 water = 49 lbs Therefor ? = 50.0 Lbs
84 930 07 Exige S |
A Man of Wealth and Taste
Potatoes weight 100 lb on the scale....of that 99lbs is water 1 lb other stuff. = 100lb
Tomorrow you come out and find shriveled up potatoes???? I don't think so... Today your Potatoes are 97 lbs.
Copyright "Some Observer" Last edited by tabs; 08-17-2018 at 02:30 PM.. |
What is the potatoes grew sprouts. Would they weigh or less than the original potatoes?
Tru6 Restoration & Design |
Platinum Member
I now concur with Redbeard and c4s.
1 lb. Of water = 7 lbs. So 93 lbs total.
Platinum Member
1 lb. Of water = 7 lbs ????
Information Overloader
But a pound of potatoes has to weigh more than a pound of water.
be here now
I had some french fries for lunch.
Rob.... '66 911, '74 911, '85.5 944, '69 914-6, '65 356C, '01 986, '04 955S, '97 993 C2S, '55 356 OUTLAW, '98 993 Cab, '55 356 Speedster, '06 955S, '58 356A, '96 993 C4S, '87 BD 911, '95 993, '06 997S, '11 997.2S, '74 914 2.7, '15 981S |
gduke2010
Approximately, 99lb
The Stick
Mathematical Potatos
P is Potatos W is water T is Taters (the part not water.) Given P = T + W = 100lb where W = 99T Find Px where Wx = 98T T + 99T = 100 T ( 1 + 99) = 100 T = 1 lb T + Wx = Px T + 98T = Px 1 + 98 = Px 99 = Px Mathematically
Richard aka "The Stick" 06 Cayenne S Titanium Edition Last edited by RKDinOKC; 08-17-2018 at 06:30 PM.. |
Edministrator
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Edministrator
The potatoes start out as 1 pound of solids and 99 pounds of water. 99/100 = 99% water.
The one pound of solids become 2% of what? 1/50 = 2%. 49/100 = 98% water. 49 + 1 = 50 pounds.
