Slackerous Maximus
987.2 Boxster, engine longevity?
I have been on a slow, lazy search for a P-car. Basically just looking at local cars as the pop up.
This 987.2 Boxster is at a local dealer. https://www.ricartused.com/used/Porsche/2011-Porsche-Boxster-columbus-ohio-3a9c94a00a0e0ae83cb3a9e899180901.htm I want a PDK/Tip, so that works. I stopped by and went over it with a fine tooth comb, looks great. Carfax shows it was hit in the rear, but no frame damage, and I can find zero evidence of it. All panel gaps good, paint correct. LOVE the blue interior and top. Dealer put new tires on it. That said, 88k is damn high miles. Given that it's a 2011, seems like it was someones daily driver. I've done a bit of searching, and these engines generally get pretty good marks for longevity, but I was wondering if anyone had any personal experience?
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Well, 2011 means no IMS, so it's got that going for it. I like low miles vehicles too, so I'd probably skip it, but if it wasn't intended to be my daily driver, then sure, why not.
The blue is nice.
White and Nerdy
This is my generic observations of multiple cars:
With modern luxury cars, I am more concerned about the age than the miles. Something to consider, when a car is sitting the oils in the plastic and rubber parts do not get distributed from flex, at a static load dry spots develop, these result in cracks. Electrical relays can corrode if not used, leading to electrical problems. Use keeps the contacts clean. Same for switches. A well used well taken care of example is a better option than a low mileage one. I would consider up to 150,000 miles as reasonable if the car is good condition. |
88k is damn high? I think way too many people still abide by thinking from when cars were first invented. 3k oil changes? Completely unnecessary. 100k is high miles and car is done for? Absurd.
My Camry has over 200k and still drives like new. My 968 has 147k and no engine problems at all. My father's 4Runner had over 230k when he sold it 2 years ago and still sees it driving around town. Cars today can and usually do go 200, 300, 400k or more if properly maintained. |
Of course, a car with higher miles probably had a much lower initial investment, and if that's the case, and you were smart and could have afforded a higher initial investment, then you should be able to afford the repairs, and potentially the rental car while it's being repaired. I would still say that a 3 year old car with 25k miles will probably have fewer repairs needed than a 3 year old car with 100k miles. THen you've just got to way the inconvenience and repair bill vs initial investment.
White and Nerdy
Those with driver cars have less problems per mile than those with rarely driven cars. Admittedly, this is just from watching forums rather than comprehensive data. Those with low mileage cars are often the ones posting problems. Those with 100,000 Miles + post about the trips they took. |
I bought a manual trans 2010 Cayman S late last year with ~72k miles, now with ~80k or so. My family absolutely LOVES the car, and it may possibly be my favorite Porsche to date.
So far it's just been typical maintenance of a car of that age/mileage. Clutch safety switch, key fob battery, and an oil change. I'm planning to lube or replace the front suspension bushings (they get squeaky when the temps get above 80), replace the engine mount (adding the softest streetable poly insert at the same time), and replace the spark plugs. Seemingly if you have reasonable DIY skills then you'll be fine with this car. While I'm not fond of the accident and auction history of that Boxster I'd have zero problems buying a reasonably priced "high" mileage 987.2. At $17,599 that car is a bargain assuming it's in good overall condition. BTW there are a LOT of 987.2 Boxsters out there. Make sure this Boxster has most or all of the options you may want. If it doesn't then hold out until you find one that does. 987.2 Boxsters and Caymans are fantastic cars! |
I bought a Cayman S about 6-9 months. Its a DFI motor, PDK with the Crono package. I have had lots of little Japanese cars that are handling monsters, Mr2, S2000. The Cayman is just so much more capable, much more then the air cool cars. A family friend is the head mechanic at LA Downtown Porsche, tells me that carbon build up on the valves are a none issue. He has seem them go 180 without major issues other then wear and tear items. I was worry about the PDK, but ensures me that if I keep up to all schedule maintenance and keep on top of oil changes, it should be good. According to him, they are tough transmissions. If it does go south, put in a new one. No rebuilt. Oh, I bought my S with a little over 68,000 on it. The interior is like a new car. It has little 80k on it now.
Is the interior Metropol blue?
Registered ConfUser
Hit in rear. For that reason alone, I’d keep looking.
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
Did you get the memo?
It's a decent price but not an amazing one. That is a bare bones base model Boxster, and is due for a major service for both the engine and PDK if not already done. Looks clean but those are dime a dozen.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
OK price but not a deal... In that range of years/price range I'd stretch for an S.. ( I say that because I had one base, exactly like above but manual, and was much happier when I got a cayman S instead) Miles? to answer your Q I'd be more concerned about whether it's on water pump #2 or #3 by now, than the actual engine mileage. At last PDK guarantees no over revs ! I think you can find a better car with lower miles for a little more $.
If it was 'hit in rear' I would want pictures of that hit, or actually know the driver well and ask them what kind of hit "Hit" is a very vague term ...otherwise love these cars .. Caymans, Boxsters, even Cayannes.. they all have nice things about them as far as I can tell. Would love to own something Porsche built in this century, one day..
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
I really had no idea they were in the the teens already. I'm out of touch. Looking for a 09+ cayman now.
Good luck, I want to see every detail of the repair if only to help when you move on from it. |
The S models are still in the mid 20s or up depending on milage and how well was it taken care of. I fine the none S model lacking a little in power
Also to answer your initial question, the 9A1 is a very solid engine. I've heard a few reports of carbon build up on the valves, but that's a potential issue with many direct injection engines. As with all of the 987s, maintenance is simple and easy. I'm not super familiar with servicing the PDK but I have heard that the service is expensive and they have a few issues with higher mileage, probably worth doing some research.
987.2 PDK is a pretty bulletproof car. Buy it, keep the fluids fresh and drive it often. I bought mine in 2015 with 45k miles on it. She now has 62k miles and 40 track days without a whimper or issue beyond brake and tire wear. Everyone I know with one in SoCal is saying the same thing. A no issues car for $15k that will give a 930 Turbo a run for it? Buy it.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) Last edited by Cajundaddy; 08-21-2018 at 05:09 PM.. |
Robust car. Get the maintenance up to date and keep it that way. You will be fine.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
