Did you get the memo?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Information Overloader
https://www.equipmentworld.com/extreme-sandboxes-are-these-3-heavy-equipment-attractions-creating-a-nationwide-craze-to-get-behind-the-joysticks/ |
When I go to Atlanta, I’d swear there is a place on the right driving through Conyers on I-20 that is a heavy machine playground. Not a big place, but looks like fun.
Edit. In my early 20’s, my friend and I drove through a neighborhood under construction late at night after a few beers. We started up a big dozer and drove around having a big time. Quote:
I borrowed this a few weeks ago for a project at the house. It was a blast to operate.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Banned
my best crane story the boat launch ramp screw up
we are at a boat ramp at the haulover cut north of miami beach the truck crane was to pull old pilings and replace them except they arrived at low tide and set up on the sloped ramp on algae the first few piles went ok but then they tryed a stuck one instead of pulling the pile the crane slid down the algae into the water and now the tide is coming back in so call a towtruck not some pickup sized but a full semi sized rig it hooks up and no way the crane is moving so the tow truck is sliding down to join the crane call in another big tow truck and still no movement then a third is hooked up now 3 trucks front wheels in the air still can't budge the crane finally a 4th truck gets there and slowly the crane is pulled out of the water that was NOT our job we were just watching on lunch break but on a water dept survey crew we watched our guys use front end loaders big back hoes hyd shovels wheel ditchers and vermears and sometime got to play with them ourselves cutting line thru the woods with a big front end loader is way more fun then a machete Last edited by nota; 11-26-2018 at 05:44 AM.. |
Cars & Coffee Killer
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Kantry Member
My next door neighbor dug the excavation for my house 37 years ago. The man was an artist with a backhoe. I have seen him excavate a level surface (to within an inch in 35 feet) without leaving the seat of the machine. He just had an eye for level.
I had serious "backhoe envy" when Ralph was working. Another guy I know was a tower crane operator. He told me a story about getting caught by an inspector, cutting corners. Late for work one morning, there were loads to shift as soon as he climbed into the cab. No time to lift the test weight. That afternoon, an inspector arrives in the cab to check up and asks him how the morning test went. My friend said, "OK". The inspector then announces he must be the best crane operator in the world, because he evidently picked up the test weight and put it back in exactly the same spot without disturbing the snow which fell last night. Busted! Best Les
Best Les My train of thought has been replaced by a bumper car. |
Unregistered
Unregistered
FUSHIGI
watched a big payloader elevate a wrecking ball (used to demo bridge)s onto a semi-trailer elevate without tilting the bucket...bucket leading edge cut the suspending cable, sending the ball through the trailer deck and the trailer about 4 feet into the air.
We demo'd an old parking garage a few months back. The machine on the right took about two hours to knock that section of the garage down.
The boom has a claw and cutter. It could eat through a 12"column like it was a stick of butter.
Well, I'm not getting anything done today.
They're putting solar panels on the roof of the building I work in. Here's hoping it doesn't tip over, because it will end up on top of me.
Platinum Member
I'd like to rig a racing seat & harness, to my mini-excavator. But I don't trust any other operators, and nobody would trust me at the controls......
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
