Help with the correct glue?
Hi guys,
An old mirror frame of my mom's that I have cracked the other day due to a drop during moving and I was hoping to ask the brain trust what glue I might use to repair it. I tried super glue and the frame literally laughed at me. I believe it is plastic, even though I believe the frame is very old. But attached are a couple of pictures that might help in deciphering what it is.
Thank you very much! Any help would be appreciated!
Old 11-12-2018, 02:39 PM
I was looking at an unopened Gorrilla Glue 2-part epoxy/glue (2 tubes > tip)...in a buddy's truck. Said it dries clear...mebbe?
Old 11-12-2018, 03:06 PM
Banned
Lottsa good glues out there, I use some called stick fast and Star Bond but whatever you use, you want to clamp it together while it dries. I have had good luck gluing stone as long as I clamped it.
Old 11-12-2018, 03:14 PM
You should identify the material before applying any real glue. If it is a type of plastic some glues will react with the plastic and melt it.
That being said you can retry the crazy glue. After applying turn to the back and sprinkle with backing soda. it will instantly dry rock hard.
Old 11-12-2018, 03:18 PM
I just looked @ the GG epoxy...I'll be picking some up...and listen to Dean & the Doc too...nice tips!
Old 11-12-2018, 03:21 PM
Brew Master
cabmandone's Avatar
My go to of late has been Gorilla Glue Super Glue Gel. I have put it on all sorts of different materials and it hasn't let me down yet.
Nick
Old 11-12-2018, 04:37 PM
MBAtarga's Avatar
Likely plastic and made to LOOK very old....
Mark
'83 SC Targa - since 5/5/2001
Old 11-12-2018, 04:41 PM
Thank you, gents!!
Old 11-12-2018, 05:31 PM
Functionista
manbridge 74's Avatar
Consider this stuff. We used it in the 918 recalls. Excellent at holding plastics. After 48 hours if you try and break it again it’ll break in a different spot not the repair....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-12-2018, 06:02 PM
Thanks, Jeff!
Old 11-12-2018, 06:42 PM
Make Bruins Great Again
Por_sha911's Avatar
Find a 2 part epoxy for plastic. There many good ones out there. I've heard Gorilla Glue has some good formulas but with any adhesive, you must use the one designed for that particular material. I use E6000 for a lot of general no heat projects with different materials. Clear, fills gaps, fairly strong. Found it in Hobby Lobby but Walmart sells it now.
Joe
Old 11-14-2018, 09:42 AM
How about some JB weld, surprising it hasn't been mentioned yet.
Cheers Richard
Old 11-14-2018, 09:55 AM
A bit late to the game (I've been away), but this is a useful site for the general form of your question:
This to That (Glue Advice)
As mentioned, the first thing you need to do is identify the material of the frame. Pot metal?? Can't tell from photo; not sure fracture surface looks like plastic.
'80 SC Targa
Avondale, Chicago, IL
Old 11-21-2018, 11:32 AM
