Burn the fire.
Tech Help Request: Rattling Doors on my Truck
Following up to my "I did a bad: bought a Ram truck" thread, I am now addressing minor projects on it. I also could not afford the fancy electric brodozer show truck soo...
The front driver and passenger doors tend to rattle quite a bit when driving on our "smooth" California roads and highways. I checked the service manual and it really only has 3 things to do: Door seals, door strikers, or latches. I would prefer not to mess with the strikers or latches and my door seals look good. What else can I do here? I am hoping one of the PPOT crowd that is more experienced with these trucks can offer some insight. Thanks!
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
No real big deal to loosen the strikers, and move them inward slightly to make the doors fit a little more tightly .
No left turn un stoned |
Depends, had an old 78 Chevy truck that the doors rattled. The hinges and pins were worn out, common to this truck, and the power window motors were too heavy for the sheet metal and began tearing the metal. All caused noise. New hinges, welding and washers for the motors, new F150 for me lol.
Patrick |
Burn the fire.
Thanks guys. Pretty sure nothing is torn/broken but I will check the hinges as well. When they rattle it feels like the whole door - front near the A-Pillars and the rear door opening. I will adjust the strikers tonight. How far of an adjustment should I make? 1/8"? 1/4"?
You might not be able to close the door if you move it that much.
Close the door with a piece of paper in the jam to see how tight the seal is pressing.
Scott '78 SC mit Sportomatic - Sold Last edited by Scott Douglas; 12-02-2018 at 09:08 PM.. |
Close the door on a shop rag.
Frankly, old truck doors are supposed to rattle a bit. |
You could try some peel/stick foam insulation strips to supplement where the door seals are supposed to be contacting the metal on the door frame.
Still Doin Time
First - you need to decern what the rattle is. Do the doors close fully and properly?
It's likely the rattle is from loose / worn out window regulator, mounting hardware, or a screw / bolt has fallen off inside laying at the bottom inside door cavity. Just remove the inner trim panel and have a look. Then drive it, listen / locate the source.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Burn the fire.
Sounds like a combo of older seals and worn out hinge pins to me.
If you don't want to go new seals on it, you could see if they're hollow. If so, get some small aquarium tank tubing and slide it inside the seal to 'fatten' it up.
Scott '78 SC mit Sportomatic - Sold Last edited by Scott Douglas; 12-03-2018 at 11:02 AM.. |
Did you get the memo?
Sadly, this is probably the most true statement. I had a 1995 F150 that was a great truck, I tried everything listed on here thus far to try and reduce the door rattle and wind noise. After trying every adjustment, additional weatherstrip, tightening fasteners, etc I just gave up. Hard to compensate for what is, at the core, a cheaply made vehicle that didn't put comfort first. Turn up the radio!
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Counterclockwise?
When you pull on the door does the rattle stop?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Crutchfield.com ....Get their biggest, baddest booming sub-woofer, and a rap cd of your choich
Bland
With the door open a few inches (like 6”), stand out side the truck at the back of the door. Grab hold of the bottom of the door and try to lift it. If you can lift the door (likely 1/2” or more), you need new hinge pins.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Burn the fire.
Quick update: It appears adjusting the door strikers in 1/8in really helped. There's still some wobble at the front of the door frame at the a-pillar, so I will look at replacing the door pins in the near future.
Thanks gents. Now on to the next project: trans fluid flush and filters.
You do not have permissi
Loosen until hand tight, slam it, open, tighten fasteners once parts are in proper place.
(works for up/down...but not in/out)
Meanwhile other things are still happening. |
