Gary H 1978 911 SC
JB Weld, Gorilla, Loctite & Flex Glue TEST
https://www.youtube.com/watch?v=H4xX7VecgzA
Yes I have always liked JB weld.....Epoxy for quick repairs
Gary H 1978 911 SC |
Testing was well executed but would like to see how vibration effects each. JB Weld fracures easily with only slight vibration.
I use Loctite's Hysol EA E-40HT for nearly everything. LOCTITE EA E-40HT Vibration, temperature, solvent and chemical resistant with extremely strong bonds. Surface prep is everything in epoxies.
Tru6 Restoration & Design |
Great video, thanks for sharing.
I use JB Weld a fair bit, so good to see this.
Ole Skool - wouldn't have it any other way |
On my T34, I had some decomposition of the engine case around the oil sump,due to the engine sitting with water in the oil. I cleaned it up really well and glooped in some JB-weld, then sanded it down once it cured. It's been several years and it's still holding up well.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Navin Johnson
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
what I like about JB Weld is it bonds to Mg very well. Every fan and housing I Cerakote is frosted like a cake with JB Weld and then sanded smooth for a perfect finish.
I can't see the link right now but I assume that is the Project Farm YouTube channel. You guys should check out his other videos, he is creative and does fun videos testing all kinds of mechanical/electrical/engine stuff.
I just watched one recently where he tested 3D printed cylinder heads on a mower engine. |
Fleabit peanut monkey
I have to do some study on Cerakote. Just rambling. I do like JB Weld and it does a wonderful job if you set up the bond site properly. Clean and enhance mechanical adhesion if possible. I do like several hours set up for the Quik but works fine for a wimpy repair in a much shorter time window. I'll watch the vid now. LOL.
1981 911SC Targa |
Exactly Bob. This fan and housing used to be horribly pitted. Frosted and then about 3 hours of sanding. Cerakote goes on in plating level thickness. Just need a good gun with a .8 tip (I use a Sata 4400) and an oven. Far superior to powder in every way.
I'm with Bill
When I built my last engine for my RX7 we did an extremely aggressive street port on it. We had to break into a water jacket in order to get the shape we wanted on the port and get the timing right.
If you do not know rotary engines it is sort of like a 2 stroke engine, you can change the port timing which is akin to an aggressive cam on a piston car. We needed to seal back up the water jacket. I refused to believe JB Weld would hold so I purchased 2 different kinds of epoxy's one cost me over $100 for a quart. We tried to create a scenario like it would experience inside the engine, we boiled it in water, we heated it up in a water antifreeze compound we also threw in some gasoline and oil. The only epoxy that held strong was the JB Weld. I still refused to believe it so I consulted two different engine builders who are renowned in the rotary world. Both said the same... JB Weld. So we used it, that was almost 20 K miles algo and 10 years ago the engine still runs perfectly, furthermore it was an engine initially designed to handle the abuse and heat of 255HP tuned to make 550HP. I knew before I started watching that video what the result was going to be.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Yes, I drill out the old solid rivets and plate the hub and associated hardware, refinish the fan and then rivet the hub back in place with a 4X gun.
You're bada55!
300hp 1800lbs is the goal
I use JBweld a fair bit. It works great to smooth out corroded metal before powdercoating.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Anyone else use JB Weld for "non traditional uses" ? Last 2 times I used it was to bed the receiver and first few inches of barrel on super accurate 10/22 builds... .
Should you need to, Kiwi neutral shoe polish makes a good release agent.... |
Burn the fire.
Thanks for sharing - he did a pretty good set of "real world" tests. His other videos are really entertaining and informative too.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Thanks Steve! One of the best parts of what I do is all the toys I get to buy, and make, to do what I want. Took four, 10 hour days to figure out how to duplicate the factory rivets and then make the jig and the set to do it. So much fun!
1981 911SC Targa |
