T77911S's Avatar
NASCAR engine AFR
I was watching some of the nascar race yesterday, BTW, no wonder NASCAR is dying. nobody can pass, they don't lift and they mostly ran in a single line.
on the in car camera, you could see the dash. on the left it "looked" like it was displaying AFR. it was showing around 14.5 at 3k under caution and 14.1 at 8300.
14.1 seems lean though.
I thought it would be richer.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-11-2019, 07:48 AM
fastfredracing's Avatar
lean is mean
No left turn un stoned
Old 02-11-2019, 08:04 AM
Unregistered
sammyg2's Avatar
14.1 is lean for full throttle and full power, but in the long run is probably the most efficient.
Max power would be reached at closer to 12.5 to 1 but if running that rich that required more pit stops, probably wouldn't be worth it.
Old 02-11-2019, 08:09 AM
Zeke's Avatar
Restricter plate plus gas mileage wins.
Old 02-11-2019, 08:11 AM
Yup. That's what makes it so exciting.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 02-11-2019, 08:45 AM
Fixed it for you.
Old 02-11-2019, 09:38 AM
Originally Posted by fastfredracing View Post
lean is mean
This. 14.7 being stoich, 14.1 is not terribly lean. Sooo many things effect power output.
Old 02-11-2019, 09:59 AM
also depends on what they are running for fuel.
1976 914
1986 951
Old 02-11-2019, 10:36 AM
Cajundaddy's Avatar
^^ Bingo! NASCAR runs Green E15 with a stoich AFR of 14.
https://www.sunocoracefuels.com/fuel/green-e15
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 02-11-2019, 10:42 AM
And it is all just spec car racing. The same chassis, the only difference is the "body shape" and the engine brand that the sponsor wants to pay the bill.
Old 02-11-2019, 11:00 AM
When you are part of "the pack" it takes less than full power to maintain that speed, so the lean condition is most likely set that way to optimize the pack racing mentality, and not full bore passing/racing of a short track.
Restrictor plate racing is a waiting game, with the goal being to still be running, and moving on the final lap (hopefully in the lead pack). Only this will give you a chance of winning the race.
Better fuel mileage will directly impact the length of each pit stop, which will gain you track position over someone who isn't dialed in efficiently. (each 1 second in the pits, is 100 yards on the track.)
Old 02-11-2019, 11:02 AM
Unregistered
sammyg2's Avatar
Which makes 14.1 VERY lean.
Conserving fuel as a strategy is no different than F-1 cars slowing down to save their tires.
Both are a result of rule-makers manipulating the rules in an attempt to make the racing more interesting.
But that usually results in exactly the opposite.
Real men don't want to waste time watching a parade.
Old 02-11-2019, 11:43 AM
