Source of power for a cell phone?
A question came up on a hiking blog I am on. If a hiker out in the boonies could not access a source of power to recharge his phone it came to my mind that it is possible to build a solar panel to power a cell phone?
Would there be sufficient power from a small solar panel? Is it doable? You techs in solar power might know this? Just a thought! Think hiker in a tinfoil hat with solar panel on top....
I googled it and there are portable chargers out there that can charge a cell phone.
Of the several hikers I follow on the youtubes, almost all of them recharge their phones with battery packs they keep on them (and recharge them while resupplying). They're good for not just phones but also cameras, ipods, headlamps, flashlights, etc. and hold enough power to recharge everything a couple times over.
With that said, power never seems to be an issue with them. The bigger problem is service. Sure they can run apps while in the boonies to stay on trail but for emergencies they all seem to use an InReach. |
a.k.a. G-man
Battery packs, backpacks with built in solar elements would work too.
https://www.theadventurejunkies.com/best-solar-backpacks-for-hiking/ Or portable stand alone solar panels.
Сидеть, ложь, Переворачиваться |
Solar options on Amazon. No idea if they are any good.
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=portable+charger+usb+solar&rh=i%3Aaps%2Ck%3Aportable+charger+usb+solar Not solar, portable rechargable batteries for charging devices via USB https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=portable+charger+iphone&rh=i%3Aaps%2Ck%3Aportable+charger+iphone
Remember when we would go backpacking to get away from it all ?
No left turn un stoned |
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
I'm in the woods a lot. I have a battery pack with solar/usb/and incandescent charging....Only costs $20...........I read where if it was dead, it would take 24 hrs to fully charge on solar....
I usually travel with my ph in airplane mode till I need. Good battery life unless snowmobiling in temps single digit or below zero.........That is hard on a battery.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Brew Master
Charge a couple of the portable charging blocks, turn off everything that eats power on the phone (wifi, location services etc...) and you should be good for a few days. If I disable all the power eating features my phone will last for a few days without charging.
Nick |
I built this one on my last hiking trip. I still have to work out the circuitry, but I'm confident it will work.
canna change law physics
We manufacturer solar powered cell phone charging stations. Probably bigger than you need, but each unit has the capability to charge 4 phones at once and a battery for use at night, which holds enough to charge 20-30 cellphones, depending on how discharged they are.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I see you
Yes I do, Not to mention that there prolly isn't much coverage in the deep woods.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
The ability to solar power a Garmin handheld gps would be an advantage. I have no idea if that is possible.... |
Brew Master
I'd go with a handheld GPS unit for nav. and save the phone for a just in case emergency.
Nick |
In the early 70's when I would live in the back country for three to four months, I would only have a transistor radio for entertainment. It took 9V batteries and ate them up reasonably quickly. So I rigged up a small solar panel I bought from Radio Shack at the time, used one or more diodes and resistors to regulate and direct the power to play my radio during the day. If I could rig something like that up close to half a century ago, there should be something now to power and store power for a cell phone.
Marv Evans '69 911E |
Waterlily turbine can be dropped in a stream or use the wind to charge a phone.
Probably not the first or fastest option but would earn street cred among the North Face nuts and berries crowd https://waterlilyturbine.com/ |
Edit: looks like reachme beat me. Last edited by drcoastline; 02-24-2019 at 02:42 PM.. |
Recreational Mechanic
I have a solar charger that I got at REI. It can charge the phone directly or you can charge up a battery back that you can then use to charge the phone at night. Works well, just slowly of course.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Geezus- do they know when I read a forum thread too? This just popped up on one of those rotating ads.
Patriot Power cell, $14.00
Navin Johnson
I [s]made[/s] assembled a small portable solar charger a few years ago from a kit..has a LiPo or LiIo battery for storage and back up..
https://learn.adafruit.com/usb-dc-and-solar-lipoly-charger It can be packaged many ways... you can even forgo the solid panel and and get the flexi fold able panels... apparently strikethrough code doesn't work [s]---[/s]
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 02-24-2019 at 07:23 PM.. Reason: vbb |
