I found a super nice gas unit on Craigslist and got a good deal on it. has a Honda engine and was stored inside by original owner. Just down the street from me too so easy transaction. I just used it on Saturday to do my driveways and it worked perfectly.
You may want to check CL and wait until a nice one shows up. The Honda engine is a real plus.
Old dog....new tricks..... |
You do not have permissi
When I replaced the pump in my gas one, the lawnmower shop said many of them use the same pump and don't last long. Not sure. Make sure the lines are primed before starting and hold the sprayer open to lessen the shock waves of on/off flow. I have a mighty sprayer that won't start unless the wand trigger is being pulled.
I have a pressure washer with the same specs as posted in the OP. It will clean a driveway just fine, but only in 2" strips.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Lots of snow Porsche away
A pressure washer is one of those tools you can find all day long used for half the cost. Electric pressure washers are not worth the investment in my experience, go gas and buy it once.
76 911S 86 GMC K1500 78 XS750 cafe racer to be 79 XS750 because one is just not enough |
Whatever you do, DON'T be this guy! I've got the same model pressure washer with the same mislabeled instructions!
Brew Master
Here's how you should base your decision in my opinion. If you don't mind dragging around a hose and extension cord, go electric. If the idea of electricity and water bothers you, buy gas. I've owned both electric and gas in small washers. The negative for a gas unit is obviously... running out of gas. The negative to electric is obviously electricity and water. Again, if both units have the same pressure and same GPM they'll do the same work. The difference in pattern is nothing more than using a different spray nozzle. I have a 15, 25 and 40 degree nozzles for my gas and electric but the electric due to a lower GPM doesn't do as well with the wider less focused spray. I also have a "turbo nozzle" that does a nice job with the electric unit. I can't use the turbo nozzle on my bigger machine because of the pressure it will produce.
Nick |
82 SC , 72 914 |
least common denominator
Timely thread, They had a Ryobi pressure wash on sale at Home Depot. Not sure what I would use it for but it sure was purdy.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Still Doin Time
I've bought too many electric ones, they never lasted more than 1 season, always a pump issue. I'm pretty anal about my tools / stuff so I take care and store properly, but still 100% failure.
Like the OP, my needs vary. You'll need something at least 3gpm to get the volume to wash an area effectively any less you'll be there all day in a small job. I find the gas versions, e en cheaper ones, better made. Units with a good quality CAT pump are expensive. I choose to rent a commercial unit as I may need 1 once/ twice a year so the cost / benefit works out better in my situation. Plus, there's a equipment rental business 10 mins from me.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
thanks everyone.
Fat butt 911, 1987 |
I would wait for a day that is pouring rain. It'll do half the work for you
82 SC , 72 914 |
I had a pressure washer that I think also had a Subaru motor. I'm pretty sure I managed to get it started without brakes. I think I put a foot on it and that "fixed the glitch". It seems like that guy just wasn't very mechanically inclined. I wasn't able to watch the whole video though. Maybe the knot in his panties was too tight. I'm assuming Scadaddle has figured out how to reliably start his PW.
Brew Master
Nick |
I've had both electric and gas pressure washers. I'm pretty sure that an electric will work fine for just cleaning concrete but the gas one will work faster due to more pressure. It might help to pre-treat the concrete with some type of cleaner. I'm not sure what type of sealer you are using but be sure to read the directions as the concrete may need to be completely dry which can take days depending on your humidity.
As for buying one, I would only buy the gas version again. This is more for convenience as you only have to tug around a hose and not a hose+electrical cord. |
All I have ever used is gas Honda powered pressure washers at work. Probably $2k.
Short story...I had a new guy and told him to pressure wash the basement of a house. Awhile later, I go check on him. He comes out and asks if I have a mask? WTF does he need a mask for. I go downstairs and he’s running the pressure washer IN THE ****ING BASEMENT. 🤪🤪🤪 He didn’t last long. |
FYI: today I went ahead and purchased the Amazon 'Deal of the Day" - this Sun Joe pressure washer:
CLICK I already have a very nice Honda powered unit but wanted to have a second electric one - more portable for smaller jobs - without have to wheel my unit uphill to the back and drag my 50' pressure hose around. My house sits on a dune ridge and has multiple ground levels front to back and side to side. Anyhow, just thought I'd mention it. About 6 hours left.
