question on pressure washer
Hope someone know.
I plan on doing my concrete seal myself (driveway, front/back yard). Every time they did it, they has to pressure washer (powerful gas machine) to blow away all residue and old seal before they can spray the new seal. Does anyone know if this pressure washer is enough for this job? Thanks. https://www.sears.com/sevencolo-sc02408-1600w-2000psi-1.6gpm-electric-high-pressure/p-A028941548
Fat butt 911, 1987 |
The strongest electric pressure washer will be much weaker than the smallest gas powered one. Check the PSI differences. But I would think a powerful electric one could do the job. That one looks marginal but I’m not an expert. For the price it might be worth a try.
Fleabit peanut monkey
Just rent a nice one. $50-75 for the day.
I like 3,000+ pounds. You will too.
1981 911SC Targa |
Recreational Mechanic
+1 on renting a nice one.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Rent one, just make sure it runs before you leave the yard.
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Brew Master
If you look at different pressure washers you'll see 2000 psi @ 1.6 gpm and others 2000 psi at 2 gmp. As I understand it you want the one with more gpm. I have the unit linked below. I personally don't believe the 2300 psi rating but then again I'm used to a 4000 psi @ 4GPM hot water unit that I normally use. I do know with my pressure turned down on the bigger unit that without the heat on it still is a stronger unit.
I'd go the rental route and get one with a heater if possible. https://www.homedepot.com/p/RYOBI-2-300-PSI-1-2-GPM-High-Performance-Electric-Pressure-Washer-RY142300/300405751
Nick |
Brew Master
BTW, if you check Amazon you'll find a LOT better deals than the one you have linked. I looked at the 2nd link before I bought the Ryobi. I think I should have gone for the one in the 2nd link. I like the hose reel. These smaller units have hose with TERRIBLE memory. I like the 3rd one linked due to Pressure and GPM
https://www.amazon.com/Sun-Joe-SPX3000-Pressure-14-5-Amp/dp/B00CPGMUXW/ref=sr_1_4?keywords=electric+pressure+washer&qid=1552956522&s=gateway&sr=8-4 https://www.amazon.com/Sun-Joe-SPX3001-Electric-Pressure/dp/B00LX8Z03K/ref=sr_1_5?keywords=electric+pressure+washer&qid=1552956563&s=gateway&sr=8-5 https://www.amazon.com/Powerhouse-International-Electric-Pressure-Platinum/dp/B07H7MQQ6C/ref=sr_1_6?keywords=electric+pressure+washer&qid=1552956563&s=gateway&sr=8-6
Nick |
AutoBahned
why don't we have robots for this?
From what I heard/learned about gas power washers was to get one with a Honda engine and a CAT pump. Such as this one:
https://www.pressurewashersdirect.com/Simpson-ALH3228-S-Pressure-Washer/p16096.html ... and look at the attachments tab. The water broom works pretty good on decks, patios, driveways, etc. I don't think the electric power washers would have the 'power'. Plus, electricity and water don't mix very well. Last edited by abisel; 03-18-2019 at 08:34 PM.. |
You do not have permissi
Pre-conditioning does half the job.
Spray it down with your eco-friendly detergent and let it sit wet for 1-6 hours. |
For electric, go $150 to $200. They're all relatively equal at that price point.
I got a Greenworks electric from Lowes, it was a Memorial day sale. So, the $200 version was $150. It will take paint off of concrete, if you spend enough time on it. I cleaned the driveway, several hours a day, 2 days a weekend for 5 weekends. Probably 40 hours run time, and it never skipped. Since then, 2 years of general use and it's still perfect. I added brass quick release connectors, a circular floor cleaner, and a foam cannon to wash the car. I love it. I spent that much time because my driveway had not been cleaned in YEARS, is 20x200ft, and needed me to use the super fine "turbo" fitting, sweeping back and forth 2 inches at a time. It was a MESS. We get mold and mildew on every surface here, and it was actually accumulating into black piles as I washed it off the concrete. Now that I stripped that all off, I can use the 15 inch circular fitting once a year, and do the whole thing in one day. I also stripped 300 square feet of desk down to fresh wood, and stripped 200 feet of cedar fencing down as well. Everything it touches, it makes pretty again.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
This entire neighborhood is filled with it for some reason, despite being on a southern hill. I see it everywhere when I walk around. Last year I power-washed the siding and now there are black mildew streaks back again. As much as I hate to do it....I'm going chemical. Wet 'n Forget works slowly and have to be applied without rain for a week or two to be effective. |
Hey Ron,
Nothing beats a pressure washer when it comes to cleaning concrete driveway. GAs is the way to go instead of electric. If its full of black gunk I would mixed bleach and some soap and get a stiff floor brush and go into town. A little elbow grease may do the trick. Get some exercise while you do some come cleaning. Bleach will get rid of the algae |
From my limited experience...you can do most small jobs with an electric...If you have all day to do an hour's work and can get very close. You can get pretty good cleaning/pressure if you have a tiny pattern.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Banned
I have an el for small jobs but borrow a buddy's gas for big stuff |
abides.
Electric is ok for spraying off patio furniture and lighter jobs. For cleaning decks or concrete, gas powered is the only way to go.
Graham 1984 Carrera Targa |
Brew Master
Think of it like a shower with a low flow head and one that doesn't have the restrictor. Both using 60 psi but one capable of doing more GPM at the same pressure, which one feels like it has more pressure? 2000@1.6 won't do the work that 2000@2 will do. Gas or electric makes no difference... it's the Pressure and GPM. A 2000 psi @ 1.6 gpm gas powered washer will do exactly the same work that a 2000 psi @ 1.6 gpm electric will do.
Here's a decent article https://www.goodway.com/hvac-blog/2011/03/flow-rate-is-key-when-choosing-a-pressure-washer/
Nick Last edited by cabmandone; 03-19-2019 at 06:16 AM.. |
We do, but they cost a few million per day to rent.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I have a gas powered one, and the disc attachment. It is still slow tedious work. It really helps to use a soap designed for cleaning concrete along with the disc. Don't expect it to just zip along and have clean concrete.
