AutoBahned
How do Penetrating Oils Work??
... at the film chemistry level, that is
I'm curious about what happens in between the threads of a stuck or corroded fastener that requires a much larger torque to "break it loose" than the spec. torque for installation. e.g. 1. does steel on the cap screw (bolt) weld or alloy to the steel on the nut? 2. does rusting produce dendritic growth of the rust itself between the two surfaces? 3. or?? and, what does the penetrating oil do to reduce the above? |
Home of the Whopper
Kinetic versus static friction?
Pen fluids reduce surface tension. Did I win?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
You have to ask? Get some Kroil and just do it.
When iron, or an alloy, rusts, the oxidation process displaces more space than the original iron, thus you get breaking of concrete from rebar rust and the space between an bolt and nut is not only "filled", but pressure is exerted between the two parts by the expansion of the rusted metal.
Can't explain penetrating oil.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
To expand on ossiblue's explanation yes, the rust, galvanic corrosion, or whatever does in fact "grow" on the parent surface. When two mating surfaces have each "grown their own", they kind of interlock their respective corroded surfaces. Penetrating oil obviously cannot make two interlocking surfaces "glide" over one another - there is a hard mechanical lock between the two. What it can do, however, is make it much easier to break the bond formed between the corrosion and its parent surface. So, if you can break the nut's corrosion off of the nut, and the bolt's corrosion off of the bolt, you no longer have a hard mechanical lock. Now you have a rust and oil slurry between the nut and the bolt. That's the whole idea.
On a related note, the very best penetrating "oil" I have ever used is simply 50/50 ATF and acetone. The acetone acts as the carrier to get it in there and soon evaporates, leaving the ATF to loosen the corrosion. Only mix as much as you need - the acetone will evaporate from the mix, leaving you with ATF again. Doesn't hurt it - just add more acetone - but it does needlessly waste acetone if you're not using it right away.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
The best penetrating fluid I have ever used is paraffin wax, melted into a very hot joint from a simple candle. I have used that to loosen critical fasteners in irreplaceable magnesium castings, after every other penetrating oil you can name failed to do the trick.
FWIW |
Heat alone is actually very good on rust. Heat the fastener cherry red with an oxy/acetylene torch and the oxides break down, reducing the rust to powder.
That’s true, but there are some parts that you can’t heat to those kind of temperatures.
Absolutely. It has to be steel on steel or cast iron. Even steel in aluminum is pretty much a no-go.
Unregistered
![]() it just does |
You do not have permissi
(only a guess)
The friction resistance is limited to the two separate sides of the threads making contact. It's not 100% contact overlap. As time and chemistry wears on, those chrome--on--chrome/iron/steel/aluminum/magnesium friction surfaces change to a rust oxidation bond from the deformed surfaces. Different metals oxidize/catalyze faster next to each other. Wicking of oils/wax occurs via surface attraction and draws it into the crevices further reducing the contact surface area. High heat also helps to melt the oxidized material and reduce overall contact. |
Brew Master
Kroil says it's the oil that creeps so I have to think creeping is involved.
Nick |
(sorry..couldn't resist)
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Jeff’s explanation is how I understand how it works. Cycling heat - oil, heat - oil can work. I have a friend who restores 100 year engines. He has several methods for freeing stuck 6 to 10 inch pistons rusted into their bores. For the most resistant he puts the assembly into a press (with pressure on the piston of course) and gets 3 or 4 guys with acetylene torches with rosebud tips to heat it up for hours. When it’s good and hot he drops a couple of pounds of dry ice on the piston. It usually works.
I wonder why there isn't a phosphoric zinc acid oil penetrating out there.
#10 to aggressively eat rust mostly but leave a little oil lube behind. #1 to cut through old grease and lubricate mostly but leave behind much protective zinc. |
AutoBahned
Thanks, Jeff, ossiblue
Milt, I have Kroil - just curious. Ultimately, you'd like to have some nanobots go in there and chip away at the mechanical 'locks' - I predict you will not see that for a long time after you see nanobots used in surgery. |
The real answer, about 1/10 as well as you hoped for when you bought the oil. Usually poorly.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I see you
https://www.bangshift.com/forum/forum/bangshift/tech-section/9336-make-your-own-penetrating-oil-that-s-better-than-kroil
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Heat is the one to beat but none of them really help at all. At least not in this test. Funny that Kroil, the most expensive, is the worst yet the people who use it swear by it.
