Spacer question
Son and I are making some changes to his miata. He wanted spacers which leads to my question. Front went on okay. The back spacer does not fit because of a non metallic ring (magnet doesn't stick to at least) that is on the hub that the spacer hole is too small to fit around. Is it a spacer issue or do I remove the ring? The spacers have the bolts attached. See picture. Any advice sppreciated. Thanks
Old 05-16-2019, 05:00 PM
Almost Banned Once
sc_rufctr's Avatar
Could it be a ring from the wheels you removed? (Some multi-fit wheels have inserts)
Is the ring plastic or alloy?
- Peter
Old 05-16-2019, 05:07 PM
It seems like a metal, not plastic. What it is made of I don't know. Thanks for responding.
Old 05-16-2019, 05:18 PM
Brew Master
cabmandone's Avatar
Wouldn't that lip indicate the wheels are hub centric? If so you might check the spacer manufacturer to make sure the spacers are hub centric.
Nick
Old 05-16-2019, 06:47 PM
They said they were hub centric.
Old 05-16-2019, 06:53 PM
Control Group
Tobra's Avatar
They sent you the wrong spacers would be my guess, are all four the same?
Yes, Miata is hub centric. It may be that the hub centering rings got stuck on the hub
Old 05-16-2019, 08:32 PM
Brew Master
cabmandone's Avatar
If you have a digital caliper, check the ID of the spacer and the ID of the wheel. That should tell you pretty quick where the problem is.
Nick
Old 05-17-2019, 05:14 AM
If there is a hub centering ring, do they just pop off with a little prying or is it typically more involved. I've lost my sense of adventure regarding just pulling things apart without asking. I've cost myself many the $ with my poor skills.
Thanks everyone.
Old 05-17-2019, 07:43 AM
DanielDudley's Avatar
https://www.miata.net/
Old 05-17-2019, 01:10 PM
I think the little ring should be removed, IIRC, from my days with a miata.
Old 05-17-2019, 06:29 PM
It popped off. I put on spacer, put ring on rim and put rim on car. Seems good.
Thanks everyone.
Old 05-17-2019, 08:03 PM
