Convection microwaves
So lame...but does anyone know anything about these appliances? What do you use them for and what are they good at if anything. We are in the midst of a kitchen remodel and a convection microwave has been suggested.
Our oven is 36” and takes a decent while to heat up. I’m wondering if a convection MW is suited to warming up slices of pizza and that type of stuff.
Uptown problems...
Thanks for any feedback.
Old 07-03-2019, 01:21 PM
Gon fix it with me hammer
svandamme's Avatar
Sounds like a combi mW to me
MW + grilll + hot air
i have one from sharp, free standing
I've baked cakes in it
there's plenty of options to do various of things with it
and it will do pizza much better then just a MW ever could
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-03-2019, 01:25 PM
Bill Douglas's Avatar
I had an early Panasonic Dimension 4. It was fantastic. Got up to temp' fast. Great baked potatoes, roasties. An easy way to do oven fries.
So I bought the latest Panasonic convection microwave as a replacement. Absolutely useless. After an hour oven fries aren't even cooked.
But the idea is good. So you have a microwave for all your usual stuff. Then when things get busy such as Christmas you have an extra oven without extra space being taken up.
Old 07-03-2019, 01:36 PM
wdfifteen's Avatar
Convection ovens and microwaves do two separate things. What it sounds like you are describing is a convection oven with a microwave in it.
Convection ovens are great. So are microwaves. I like to keep the separate. You don't want to be locked into spending more $$$ repairing the microwave in your big oven when you could just buy a new microwave for less.
Best of both worlds. $150 Sharp microwave up top, $700 Bosch convection oven down below. The convection oven has a "rapid heat" function that uses the convection system for pre-heating. Works well.
Old 07-03-2019, 02:28 PM
The first microwave that my parents bought in the 80s was a convection microwave. I wasn't old enough to know or care what it did other that act as a microwave.
The oven we bought about 15 years ago was a convection. It was good, better than a regular, I think.
Old 07-03-2019, 02:54 PM
Zeke's Avatar
Convection with micro is called by various manuf a speed cook oven. It can use both simultaneously, all halogen, top or bottom, both and all microwave. Best appliance in my kitchen. I have the halogen kind.
Spendy. https://www.geappliances.com/ge/advantium-oven.htm
Also there is an heat element powered version that is more common. Some have a broiling function. So then you would have a salamander. When mine (GE Advantium) dies for good ( I've already torn the thing down to the base to replace the lower lamp — $140 for that — the upper one is 250), I'm going to another brand/type like Bosch or Jenn Air.
Some of these damn things are way up in the $1000's. Some are 2 grand or a bit more. That's my speed.
On another note these are no substitute for a big oven for the turkey, etc.
Old 07-03-2019, 03:25 PM
Banned
we had a used GE that did both mw and convection heat it broke
unless space is a problem I would just get two units
as the combined unit is way too high priced 450+ and up
vs 100 or 2 each
also watch out for the exit vent it can melt a counter top or backing and start a fire
Old 07-03-2019, 03:52 PM
A convection oven is basically a standard oven wirh a fan. Air is circulated which keeps a more consistent temperature within the oven.
A micowave convection oven will have some type of heating element and a fan to circulate the air. Microwave cooks from within while the convection oven heats the circulating air which adds outside browning and crisping..
Old 07-03-2019, 04:16 PM
Thanks for sharing all the thoughts/experiences. Sound s like I should investigate it a little further.
Old 07-04-2019, 07:01 AM
Platinum Member
dad911's Avatar
Frosts me every time I pay as much (or more) for a microwave trim kit as the microwave itself......
Old 07-04-2019, 07:11 AM
VincentVega's Avatar
^ no kidding, crazy
I went with a shelf and a ~$100 microwave instead of a built in. Great for when/if I need to replace.
Boils down to what you use it for. I dont see the need, but I have a pair of convection ovens when I need to bake a lot. To me a microwave heats up leftovers and occasionally something else. I'd rather spend the $$ on a better range or wall oven.
Old 07-04-2019, 09:48 AM
wdfifteen's Avatar
+1 on that!
Old 07-05-2019, 04:30 AM
