Information Junky
island911's Avatar
you likely do. But if you find some hard to get to screw --like on newer cars designed in CAD-- it's nice to know what's available. They sell direct or thru Amazon. I buy direct.
Old 07-10-2019, 09:02 AM
AutoBahned
RWebb's Avatar
I couldn't figure out the different designations for the Chapman screwdriver sizes. May try on a browser window w/o any blocking for popups, etc. on it.
I did however find some SWISS screwdrivers...
https://www.shop.pbtools.us/PB-8135-SwissGrip-Stubby-Screwdriver-for-Slotted-Flat-screws_c418.htm
Old 07-10-2019, 11:19 AM
If you have original Webers, then your best move is to make a custom screwdriver by meticulously filing down one that is slightly too wide.
Old 07-10-2019, 10:18 PM
You do not have permissi
john70t's Avatar
I know you don't want to make a new tool, but adding a perpendicular stub helps in fine-tuning angles and remembering number of turns.
Old 07-11-2019, 05:50 AM
I see you
flatbutt's Avatar
Have mercy guys please!! I'm on a fixed income. Yer killin' me with these awesome websites!
Old 07-11-2019, 06:43 AM
Information Junky
island911's Avatar
^ I know. right?
I couldn't figure out the different designations for the Chapman screwdriver sizes. ...
https://chapmanmfg.com/collections/individual-parts/products/slotted-insert-bits
Pull-down menu gives dim's.
Old 07-11-2019, 10:05 AM
AutoBahned
RWebb's Avatar
Thx
BTW, I found a nice looking Hazet but it is $26 or $41 (2 sellers) - seems crazy
The SnapOff and others are mostly in the $10-$14 range
Old 07-11-2019, 10:40 AM
gtc gtc is offline
abides.
gtc's Avatar
I'd take a Craftsman stubby and melt the shaft out, then cut off and epoxy in a tip i liked from another screwdriver.
Graham
1984 Carrera Targa
Old 07-11-2019, 12:54 PM
Zeke's Avatar
I seem to get along fine with my assortment of orphan screwdrivers plus a set of CM in flat and Phillips. I have some SO and other "truck" brands as well. A good CM is as good IMHO.
The trick is to have the blade of a taper model just not quite bottom out. If it has any movement before you bare down with the torque, you're heading for a problem. I have more flat SD's because I have lots of thicknesses to fit screws of many origings. On the antiques I work on there will be nothing but slotted screws and I need to keep them so they don't look like they have been used.
The so called hollow ground models allow not a fraction of tolerance. If the slotted screw has already been buggered, no screw driver alone will help much. You have to resort to the various 'tricks'. I have a drawer for all those tools as well.
Agreed about special equipment like Webers. Get or make a SD that fits perfectly and keep it fresh and not to be used on your Briggs and Stratton or as a chisel.
How many kludges do you know that have used their SD's for everything? I keep a drawer with dead ones for just that. I'm not immune from abusing tools. I just know which ones to beat on.
Old 07-11-2019, 01:25 PM
canna change law physics
red-beard's Avatar
https://amazon.com/Screwdriver-Multi-Bit-Klein-Tools-32561/dp/B005FQDHHC/ref=sr_1_3?crid=M739FJETI8R5&keywords=stubby+adjustable+screwdriver&qid=1562877805&s=gateway&sprefix=stubby+adju%2Caps%2C151&sr=8-3
James
Red-beard for President, 2020
Old 07-11-2019, 01:44 PM
What can I say, Milt knows his stuff when it comes to tools. Well done.
Old 07-11-2019, 03:08 PM
AutoBahned
RWebb's Avatar
I had my eye on that Klein for a while - we'll see how the Swiss ones do.
Other brands I looked at:
Hazet - too spendy
Tecton
Wera
Wiha - have a bunch of different blade thicknesses
- a few others I forgot
I rejected Crapsman as being too crappy - the horizontal ridges on the blade are just stamped in - rounded in profile and don't help hold it in the slot well. I have 2 of them and use them as pry bars... or loaners.
Old 07-11-2019, 04:59 PM
Originally Posted by Zeke View Post
...or as a chisel...
Oh lord that's my life. I keep a pristine set of Wihas locked up and hidden - my PhD Engineer wife believes that every screwdriver wants to grow up one day to be a chisel.
A SD that fits perfectly is a pleasure to use.
'78SC, lots of other boring cars...
Old 07-11-2019, 05:25 PM
Brew Master
cabmandone's Avatar
Yer takin all the fun out of it if you're not willing to get creative!
Nick
Old 07-11-2019, 07:03 PM
A930Rocket's Avatar
Flashback...
I come home from work one day and my wife had taken one of my Snap On gasket scrapers and was using it and a hammer to cut bricks in half.
I was not happy. 😡
Old 07-11-2019, 07:37 PM
Flashback...
I was not happy. ��
Thats what I was thinking! If its anything like my tools. I have 50 screwdrivers in a drawer only to find my favorite flathead with no tip on it. My brother or dad use them for prybars and chizels. Wont be long till all my old usa made tools are busted. Cant have anything nice
Old 07-11-2019, 07:49 PM
Zeke's Avatar
My wife broke the tip off a 10" French cooking knife. It was a Henckel.
Old 07-12-2019, 01:12 PM
