A930Rocket's Avatar
How do I connect a tablet/laptop to a monitor?
How do I connect a tablet/laptop to a monitor? With a 13” screen, it’s difficult to read some spreadsheets or programs and a monitor would really help.
The tablet/laptop has (1) USB B and (2) USB C ports. The monitor has (2) HDMI and (1) D-Sub In.
I’ve read that the cable and/or laptop needs to be video/audio capable.
Or is an adapter the best way?
Thanks!
Old 07-14-2019, 02:44 PM
My other ride is a C-130J
RNajarian's Avatar
If you are running Apple products. . . .
An iPad connected to an Apple TV (we’re using Apple TV gen 4) then air drop it through the Apple TV. My monitor is 75 inches, easy to see.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 07-14-2019, 04:13 PM
The Unsettler
stomachmonkey's Avatar
USB C carries video.
Might as well expand your connectivity options while you are at it.
I personally use these so can confirm they work.
https://www.amazon.com/gp/product/B077FZQS95/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
"I want my two dollars"
"Brandon Won"
Old 07-14-2019, 04:36 PM
If it’s got 2x hdmi , just plug it into your tv whenever you need a bigger display .
Old 07-14-2019, 05:46 PM
The Unsettler
His monitor has 2x hdmi, device only has USB.
Sounds like a convertible, maybe Surface Pro, a Yoga or similar.
Would help if OP told us make model of device.
"Brandon Won"
Old 07-14-2019, 05:48 PM
A930Rocket's Avatar
It’s a Targus if I’m not mistaken. Just got it from our IT dept, so I’m not real familiar with it. I’ll have to post the model tomorrow, as it’s at the office. It does act as a tablet that can fold over, touch screen, pen screen, etc.
Old 07-14-2019, 08:10 PM
A930Rocket's Avatar
I have one that plugs into my USB C port. My printer and wireless mouse plug into it.
Old 07-14-2019, 08:16 PM
crustychief's Avatar
Are you using a docking station? probably not. there are USB to VGA adapters that you can use.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
A930Rocket's Avatar
No docking station, but I did see something on the bottom that might be part of one.
Old 07-14-2019, 08:19 PM
A930Rocket's Avatar
The two HDMI and the VGA(?) on the back of the monitor.
Old 07-14-2019, 08:21 PM
The Unsettler
The monitor does not matter beyond that it supports HDMI.
The laptop needs to support usb c dp alt, (display port alternative via usb c)
If it does not have a standard video out port it’d be an absolute fail if it did not support usb c dp alt.
Just grab what I linked, forget a docking station. I have several of them between home and office and all my guys use them as well.
"Brandon Won"
Old 07-14-2019, 09:01 PM
A930Rocket's Avatar
Thanks SM. I’ve ordered one.
Old 07-15-2019, 03:40 AM
A930Rocket's Avatar
It’s a Dell Latitude tablet with a Targus case/keyboard.
Old 07-15-2019, 07:57 AM
According to Dell, that has
1 Headset/mic combo jack
1 USB 3.1 Gen 1 (Type A)
1 USB Type C (Power delivery & DisplayPort support)
1 USB 2.0
1 HDMI 1.4
So just plug the HDMI connector (it's almost certainly a mini type E or type F https://en.wikipedia.org/wiki/HDMI which is why you didn't recognise it) into the TV HDMI in with an appropriate cable. HDMI also carries audio. Or buy a USB-C adapter with a DisplayPort->HDMI cable.
Some older/smaller TVs - or cheap ones with poor implementations, like you often find in hotels - may not work well with being asked to display 1080p or above.
Another option is plug a Chromecast/FireStick into the TV and just cast the entire display.
'77 S with '78 930 power and a few other things.
Old 07-15-2019, 10:37 AM
A930Rocket's Avatar
I ordered what SM recommend along with a USB C to HDMI cable.
I’ll know in a day or two what works.
Old 07-15-2019, 08:23 PM
