Brew Master
You could do a search for "refrigerator inefficient compressor". You might find some temperature readings on the suction and discharge lines that will point you in the right direction.
Do you have a LG/Kenmore? If so you likely have the Linear Inverter compressor and it might be covered if the LG warranty extension applies to Kenmore fridges with compressor issues. LG had a large class action suit against them for compressor failures.
Nick |
Banned
we had to do that often as the boats motion did in the unit's gas/liquid balance but I also got a non-cooling el compressor fridge to cool by flipping it kind of voodoo as I have no idea why it worked but it did yes watch the compressor for displacement on the springs |
Are both freezer and fridge equally not cool at all (the same)?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Super Moderator
Yes. they use a single evaporator and fan - with a splitter duct.
Super Moderator
a.k.a. G-man
didn't read the whole thread so maybe this has been mentioned before?
Faulty temp sensor. Had this at my parents's house. Replaced sensor, problem solved.
Сидеть, ложь, Переворачиваться |
Brew Master
Nick |
Information Junky
Do you have clean power? I once had a problem with an outlet... it always showed voltage and 'ran' the compressor(some vibrations) but the unit would remain room temp.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Super Moderator
UPDATE:
Technician came out and verified it has the LG linear compressor that fails after 3 years. LG covers it under their warranties on LG refrigerators. Sears covers it only on the Elite models. For me? It costs as much as a new one to repair. I've called 6 different departments at sears and they all claim 'someone else" handles that. The same part - same model - etc.. 10 year warranty on the "Elite" line. NO warranty on the standard line. I will never EVER buy another item from sears ever again ANOTHER UPDATE!!! I've called 10 differnet numbers provided. They all lead to the service center. I finally got through to a Supervisor and they pawned me off on "Kenmore CUstomer Care". That number is a spam line. You have to listen through 20 BS spam offers (auto insurance, home care, etc..) and then at the end of rejecting all of those, it send you to another phone number which is "Free 411". In other words - there is NO WAY to speak to a person at sears at all. Beware.
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 08-30-2019 at 09:53 AM.. |
Super Moderator
I believe I will be loading this appliance up into my truck and dropping it off at the local sears location.
Information Junky
or...
https://www.classlawgroup.com/consumer-protection/lg-fridge-compressor-failure-lawsuit/ DK. Sucks for sure.
Super Moderator
I found replacement compressors online and the piercing valve, but there is conflicting information as to whether or not you need to re-program the control board when putting in the newer style compressor.
No way to find out...
No you don't have to reprogram. Just run temp settings a tad lower. You WILL need a vacuum pump to get ALL the air out no matter what anyone says! The Freon charge will have to be known as you just can't shove a bunch of it in! If it were me I would buy the two stage vacuum pump HF sells for about $150 or so, a gage set so you can watch the pressure difference across your new compressor as it will have the specs with it.
Or just pay to have someone do it for you. |
Super Moderator
Thanks John - they want $1000 to repair a $1400 fridge.
I might be able to scare up a vacuum pump from the auto community -
You do not have permissi
Thank you for the warning. |
Super Moderator
If you have time, do a search on ANY review site on LG and Kenmore refrigerators and you'll see a staggering number of people that had theirs fail in 2-3 years. No coverage, no care. I bought Kitchenaid (Whirlpool) as they have the lowest repair rates of all.
Make Bruins Great Again
Who designed Equifax Customer Service? I had to do an online search just to find a number to talk to someone. Had the same problem with Paypal a few years ago. And while we're at it DON'T buy a DELL Computer: there is no way to talk to someone from Dell Computers inside the USA (as of a few years back when they ripped me off and I vowed to never deal with them again). They won't even give you the information as to where to write to the corporate office (which I finally found online and wrote a letter but never got a response).
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Senior Member
Given the disturbing stories I have read here and elsewhere, it was with some reluctance I purchased a Whirlpool side by side from Costco yesterday, and the extended warranty. This unit does not even HAVE an ice-maker.
With warranty and tax, just a little over $1K. Fingers crossed.Here is the unit I am replacing. A Kenmore from the Plasticene period about 400 million years ago. I bought it used for the princely sum of $100 about a dozen years ago. It makes a little noise and the water system once turned my kitchen into a lake but otherwise it has been a good girl. I even considered checking into a full rebuild of this unit given the reliability, or lack thereof, of modern 'fridges.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
That might be cheaper over the long haul, and cause you less aggravation.
