Platinum Member
Ferrous Circular saw Blade
So has anyone ever used a ferrous blade for cutting steel on a chop saw?
It goes against anything I've done before, I usually use a grinder or sawzall. The blades seem to get good reviews, cleaner cut, faster.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Non Compos Mentis
Works great.
But the small grit will get into the hinge of the chop saw and eventually wear it out. The whole saw will get sloppy while the hinge gets harder to use. Guys that frame metal buildings love to pick up used chop saws cheap because they consider them disposable tools. Fine for occasional use. They will last quite a while. Just know they will get less precise over time. |
I've used one on 1/8" angle iron. I go very slow thru the material.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Motorsport Ninja Monkey
I quickly glance the title and read it as 'Ferocious Circular Saw Blade'
Was slightly unsure what I was going to read
Wer rastet, der rostet He who rests, rusts |
Get a proper metal cutting chop saw. If you like it and use it alot then think about investing in a toothed blade. The chop saw is good for big stuff but I use one of these alot more
82 SC , 72 914 |
The pivot point of the chop saw takes a beating from the flying metal dust/chips as stated above . Make a " sock " of leather around that joint to stop the intrusion . Replace as needed when it wears out or burns through .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Platinum Member
https://smile.amazon.com/Diablo-D0842CF-8-inch-Carbide-Ferrous/dp/B00PB7NF8Q/ref=sr_1_18?keywords=Metal-Cutting+Circular+Saw+Blade&qid=1569110293&s=hi&sr=1-18 Max RPM of blade is 9000, I have a 20 yo makita miter saw that spins about 4000.
Platinum Member
I hate to admit how many miter saws I own. Already dedicated an old makita for aluminum, would use that one.
Fook that. Call me chicken, but steel pipe with a circular blade? I am sure it works and works well, but I am like you, having second thoughts about anything with teeth that will get caught and through it across the room. My guys likes to use the grinder, but I like abrseive blade on my worm drive. No metal chop saw?
Got this one. https://fein.com/en_ca/sawing-and-cutting/metal-cutting-saws/14-in-slugger-metal-cutting-saw-0302133/
Works very well on tubing, flat bar etc.. |
Platinum Member
Makes sense, rrental. That saw is 1300 RPM.
Platinum Member
What saw are you using, and does the blade last?
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
An old Makita miter saw. How do I tell you if the blade lasts? Yes it does. How long? I didn't time it.
I had no idea they made a blade like that for metal. I’ve used my miter box for thin aluminum and was nervous about that.
I have used the smaller blade made as Diablo, 6 1/2" to be used on my battery powered dewalt skil saw for cutting ferris metal. I have used it to cut angle 4" by 1/8".
Will last but if it gets stuck the teeth will break, I would buy them 2 at a time but saved me time over the long haul I was paying $65.00 Canadian ea. Do where safety glasses.
Larry 1971 911T 1983 Envemo, Cabriolet 1989 Carrera Cabriolet |
canna change law physics
I have a metal blade in my "Chop Saw". I use it for aluminum. The blade is rated for steel. With Steel, I expect it will be a spark fest. I agree with other, go slow.
Protective gear will be a must, long sleeves made of cotton, heavy work gloves, eye protection.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
You do not have permissi
Blowing out the sliding parts (esp the rotating base) and lubing w/teflon spray helps. Even a can of keyboard duster is better than nothing. |
