Platinum Member
dad911's Avatar
Ferrous Circular saw Blade
So has anyone ever used a ferrous blade for cutting steel on a chop saw?
It goes against anything I've done before, I usually use a grinder or sawzall. The blades seem to get good reviews, cleaner cut, faster.
Old 09-21-2019, 07:35 AM
Non Compos Mentis
Works great.
But the small grit will get into the hinge of the chop saw and eventually wear it out.
The whole saw will get sloppy while the hinge gets harder to use.
Guys that frame metal buildings love to pick up used chop saws cheap because they consider them disposable tools.
Fine for occasional use. They will last quite a while. Just know they will get less precise over time.
Old 09-21-2019, 07:51 AM
I've used one on 1/8" angle iron. I go very slow thru the material.
Old 09-21-2019, 11:11 AM
Motorsport Ninja Monkey
Captain Ahab Jr's Avatar
I quickly glance the title and read it as 'Ferocious Circular Saw Blade'
Was slightly unsure what I was going to read
Wer rastet, der rostet
He who rests, rusts
Old 09-21-2019, 01:46 PM
Get a proper metal cutting chop saw. If you like it and use it alot then think about investing in a toothed blade. The chop saw is good for big stuff but I use one of these alot more
Old 09-21-2019, 02:10 PM
rfuerst911sc's Avatar
The pivot point of the chop saw takes a beating from the flying metal dust/chips as stated above . Make a " sock " of leather around that joint to stop the intrusion . Replace as needed when it wears out or burns through .
Old 09-21-2019, 03:47 PM
Platinum Member
dad911's Avatar
Originally Posted by Zeke View Post
I'm not sure what you are calling a ferrous blade but a cold cut blade runs less than half the speed of a wood cutting chop saw. You want to get hurt, put one on. IOW, buy the correct saw.
I was looking at something like these:
https://smile.amazon.com/Diablo-D0842CF-8-inch-Carbide-Ferrous/dp/B00PB7NF8Q/ref=sr_1_18?keywords=Metal-Cutting+Circular+Saw+Blade&qid=1569110293&s=hi&sr=1-18
Max RPM of blade is 9000, I have a 20 yo makita miter saw that spins about 4000.
Old 09-21-2019, 05:06 PM
Platinum Member
dad911's Avatar
I hate to admit how many miter saws I own. Already dedicated an old makita for aluminum, would use that one.
Old 09-21-2019, 05:08 PM
Fook that. Call me chicken, but steel pipe with a circular blade? I am sure it works and works well, but I am like you, having second thoughts about anything with teeth that will get caught and through it across the room. My guys likes to use the grinder, but I like abrseive blade on my worm drive. No metal chop saw?
Old 09-21-2019, 08:41 PM
rrental's Avatar
Got this one. https://fein.com/en_ca/sawing-and-cutting/metal-cutting-saws/14-in-slugger-metal-cutting-saw-0302133/
Works very well on tubing, flat bar etc..
Old 09-21-2019, 09:33 PM
Platinum Member
dad911's Avatar
Makes sense, rrental. That saw is 1300 RPM.
Old 09-22-2019, 06:02 AM
Platinum Member
dad911's Avatar
What saw are you using, and does the blade last?
Old 09-22-2019, 06:03 AM
peppy's Avatar
I have a blade like this. I used it to cut the metal trim for a tile back splash. It scared me every time I used it, but did make nice cuts.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-22-2019, 07:02 AM
An old Makita miter saw. How do I tell you if the blade lasts? Yes it does. How long? I didn't time it.
Old 09-22-2019, 05:55 PM
A930Rocket's Avatar
I had no idea they made a blade like that for metal. I’ve used my miter box for thin aluminum and was nervous about that.
Old 09-22-2019, 07:43 PM
upwardr's Avatar
I have used the smaller blade made as Diablo, 6 1/2" to be used on my battery powered dewalt skil saw for cutting ferris metal. I have used it to cut angle 4" by 1/8".
Will last but if it gets stuck the teeth will break, I would buy them 2 at a time but saved me time over the long haul
I was paying $65.00 Canadian ea.
Do where safety glasses.
Larry
1971 911T
1983 Envemo, Cabriolet
1989 Carrera Cabriolet
Old 09-22-2019, 08:02 PM
canna change law physics
red-beard's Avatar
I have a metal blade in my "Chop Saw". I use it for aluminum. The blade is rated for steel. With Steel, I expect it will be a spark fest. I agree with other, go slow.
Protective gear will be a must, long sleeves made of cotton, heavy work gloves, eye protection.
James
Red-beard for President, 2020
Old 09-23-2019, 04:49 AM
You do not have permissi
john70t's Avatar
I burned out the laser guide that way while making a small curved walkway.
Blowing out the sliding parts (esp the rotating base) and lubing w/teflon spray helps.
Even a can of keyboard duster is better than nothing.
Old 09-23-2019, 07:15 AM
