engine block heater Duramax, freddy, anyone?
Anyone know if Chevy installed a block heater in their Duramax trucks as a standard package and not optioned. I read somewhere that they all have it? I am driving up to Calgary then onto SK this Christmas so block heater is almost a must. Any other alternative to the block heater if there isn't one from factory? Sticky em' on pad heater?
I know many of you live in the cold but what weight engine oil do I need to keep starting easier? Last time I was up there with my truck back in the mid 80s, my lil' Toyota froze. Lucky it didn't bust the radiator. I am going to remove half of my coolant to make it 75% instead of 50% live we have here
Old 11-18-2019, 11:31 AM
Still Doin Time
asphaltgambler's Avatar
If installed- your owner's manual should show where the plug would be. Start there
Old 11-18-2019, 11:44 AM
rfuerst911sc's Avatar
On my Duramax dually model year 2001 the block heater plug was behind the passenger headlight and under the air filter box . It was taped into a bundle . I cut the tape and neatly draped it behind the air box for easy access . Have never used it .
Old 11-18-2019, 12:18 PM
Forgot the oil , go with 5W40 synthetic for best low temp starts . Several brands of diesel oil in that weight : Rotella , Mobil 1 , Chevron Delo are examples available almost anywhere .
Old 11-18-2019, 12:21 PM
I would have no idea what the damn thing look like? Any possible way to get a pic of this plug for me?
Old 11-18-2019, 12:31 PM
It's just a regular male outlet plug that plugs into an extension cord . Standard black color .
Old 11-18-2019, 12:37 PM
it was taped up in the engine bay behind the head lights?
Old 11-18-2019, 01:14 PM
fastfredracing's Avatar
Same place on mine . Right behind the passenger headlight. I have never used it . Im pretty impressed with how well it starts in the cold .
No left turn un stoned
Old 11-18-2019, 01:25 PM
Yep you might have to remove the air filter box for better view .
Old 11-18-2019, 02:37 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Just sayin'. You are going at Christmas time not February.
1981 911SC Targa
Old 11-18-2019, 03:39 PM
Try looking for it just about 20 min ago with a flashlight with the head light off, no dice. Crawled under the truck, still nothing. Pulling the air cleaner tomorrow. Thanks for the tip.
Old 11-18-2019, 05:29 PM
Bland
unclebilly's Avatar
yup, mine has it.
You may not need it but then again you might... 2 years ago it was -40 on Christmas night.
If you want to stop by for a coffee or a beer, we'd love to have you.
Old 11-18-2019, 05:43 PM
Originally Posted by unclebilly View Post
yup, mine has it.
Typically it gets down to 10-15 below is the norm. Going to Regina and some small towns for a couple days to track some of the roots of my relatives. I thinks it get colder there with wind blowing in the empty hotel parking lot may freeze. You know if most hotels offer electricity for heaters?
Love to have a cup of joe if possible.
Old 11-18-2019, 11:28 PM
Team California
speeder's Avatar
A couple of things:
Trucks sold new in Southern California generally aren't equipped w block heaters. My diesel PU came from Idaho and has a block heater. You might have to install one. Go on a Duramax forum and ask where it is on the engine and see if you have one. You might just be missing the cord.
Secondly, a 75% ratio of anti-freeze to water has a HIGHER freezing point than 50/50, not lower. Read the back of the coolant jug for ratios and temperatures. Better yet, find a competent shop that works on Duramax trucks where you can take it and have your coolant checked for freezing point. It may be fine now. Doesn't that thing have pink GM coolant?
It sounds like you're in over your head, here. Take it to someone who knows the trucks and they can check and install a heater if necessary and check your coolant while you make $$ doing what you're good at.
Denis
Old 11-18-2019, 11:50 PM
That's what Im thinking too, Socal truck without the cord. Pink coolant, yep. You know any good diesel shops around here, Dennis? Many diesel people are interested in working on big trucks, not pick ups. I am going up to Utah next week for a bit of skiing and see Arches NP with kids but not worry too much about low temps up there. I might be able to do this after I get back.
Old 11-19-2019, 12:21 AM
Team California
speeder's Avatar
Just take it to the dealer and have them check the coolant that is in it for freezing temp and ask about the block heater. If the coolant hasn't been messed with, it should be fine. Might even be original, it's a "lifetime coolant."
If it needs a block heater, get a quote in writing w the part number or numbers and go to work on the internet looking for a cheaper price. That's how it's done.
Denis
Old 11-19-2019, 01:11 AM
Bland
unclebilly's Avatar
Most hotels will have plug ins for a block heater.
What year is your duramax? I have the top end on my 03 partially ripped apart so I can check on wire routing for you.
Looking forward to the coffee.
Old 11-19-2019, 02:10 AM
When in doubt Youtube it This should help you out .
https://www.youtube.com/watch?v=vuYmsx_mZvk
Old 11-19-2019, 07:36 AM
Team California
speeder's Avatar
Youtube FTW. What on earth did people do before YT, besides scratch their heads and guess?
Denis
Old 11-19-2019, 07:50 AM
most hotels will have plug ins for a block heater.
What year is your duramax? I have the top end on my 03 partially ripped apart so i can check on wire routing for you.
06
Old 11-19-2019, 09:11 AM
