jyl jyl is online now
jyl's Avatar
replacing water heater
I need to replace my water heater. Have been limping it along by replacing components, but when the basement floods, it’s time.
It is an AO Smith FPSH50 50 gal gas power vent model. I ordered the AO Smith model that is supposed to be a direct replacement, the GPVT50 50 gal gas power vent model. Supposed to be same gas pipe diameter, same water pipe diameter, same PVC vent pipe diameter. The new one is about 4” taller so I may have to rework the PVC vent pipe a little.
Any tips on replacing a water heater? Just a matter of unstrapping and disconnecting the old one, putting the new one in place, reconnecting and restrapping, and maybe reworking the PVC vent pipe?
Any non obvious precautions when working with gas? The supply valve is right by the water heater and is shut off.
Any little things to do, to help the new ones last longer? The current one lasted 20 years, I’d like to get that long from the new one. Our water is very soft.
I don’t love doing this stuff but the “water heater repair” companies all want $3-4K and I’m not going to pay $1.5-2.5K over the price of the replacement heater. I’m already paying $1.4K to get the heater tomorrow from a local place instead of $1.0K to order it online; I figure supporting a local place and not having to wait 1-2 weeks is worth it. Big party on Friday so would be nice to have hot water for dishwashing etc.
Fortunately my neighborhood is having a “cleanup” next month so for a $100 donation I can get rid of the old heater. Places charge $500 to haul these away!
Old 02-24-2020, 10:59 AM
jyl's Avatar
P.S. Do these this really weigh 200 lb as stated in the specs? Doesn’t seem possible, just a sheet metal tank ...
Trying to figure out if I need to recruit a buddy to help move it into the basement.
Old 02-24-2020, 11:08 AM
rfuerst911sc's Avatar
A few tips.
1. You need to drain current tank assuming it didn't all leak out. Attach a garden hose to the drain valve . Make sure incoming water valve is closed . Run hose outside and open the drain valve . Slowly open the expansion valve normally on top of the heater . Open some hot water taps in the house this will help empty hot water pipes .
2. Once the tank is empty disconnect all plumbing and gas line and vent pipe .
3. At this point you should be able to move/remove the tank .
Clean up the area and do any maintenance needed like paint or anything you couldn't do because the tank was in the way . Then start the new install . Gas pipe use good pipe sealant and make connections tight . Same for water connections . Good luck
Old 02-24-2020, 11:11 AM
Wow, 500 to haul away a heater? That's nuts....in addition to the above, if you have copper pipes, use dielectric unions to connect to the tank.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma
Old 02-24-2020, 11:17 AM
Siht, 3-4 k to replace water water? I am moving up to Portland. We charge 400-450 bucks labor plus heater. I don't do water heaters, but will do it s part of the construction package but I will change out heater for the nice old lady in my hood.
You will be very lucky to get your new heater to last longer then 15 years. Avg life span for new heaters is 12-13 years. unhook everything and reinstall. Bleeding air out of the gas line is the most painful. Its a long boring wait of 45 seconds to a min. Change out the old gas line.
Old 02-24-2020, 11:20 AM
Access good into basement? I only had to install a few heaters in my entire life. One of them is for myself and others for my parents. I use a hand truck. The trick to carrying it into place is to do a bear hug and pick up that way. My plumbing can do it all by hid lonesome self lifting it that way.
Old 02-24-2020, 11:22 AM
500 bucks to haul away a heater? Siht, I thought construction was expensive in LA, damn. We leave it out on the curb and the recycling guys in their Sanford and Son truck will snap it up in no time. Normally we just have plumber take it back to plumbing supply and dump it there. Its free, they recycle it.
Old 02-24-2020, 11:28 AM
pete3799's Avatar
Don't forget to check your gas line fittings with soapy water after install.
Pete
79 911SC RoW
Old 02-24-2020, 11:32 AM
Arizona_928's Avatar
You should get around 10$ for it from the scrap yard.
They're simple to replace. Might need a longer gas line. My did, and only Lowe's carried it.
dolor et pavor
Copyright
Old 02-24-2020, 11:40 AM
Burn the lining out and make a smoker out of the old one!
Brent
Old 02-24-2020, 11:54 AM
canna change law physics
red-beard's Avatar
They are glass lined, hence the weight.
James
Red-beard for President, 2020
Old 02-24-2020, 12:06 PM
LWJ LWJ is online now
John,
I have a utility trailer you can use and take that to the scrapper for free.
You got this. It is very simple. I have done many.
Old 02-24-2020, 01:25 PM
Banned
Why not get on demand and get rid of that ancient contraption?
Zeke's Avatar
If it has a PVC vent it's a HE unit.
Old 02-24-2020, 01:56 PM
jyl's Avatar
Want the 50 gal water for earthquake . . .
Old 02-24-2020, 02:17 PM
jyl's Avatar
Insane. I live in a big house in a nice area. Water heater companies come here and they think I'm loaded and stupid. I've had 3 come over the years, same result. Each time I've waved them goodbye and found a way to fix the unit. Refuse to give those crooks money.
Old 02-24-2020, 02:19 PM
jyl's Avatar
Thanks and if you don't hear from me again, something went wrong with the gas part.
Old 02-24-2020, 02:21 PM
Use a regular hose to drain it, not an expanding one, with the pressure off the expander will dribble until it 'looks' like it's all empty. BTDT, made a mess.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 02-24-2020, 02:27 PM
If your gas line doesn't have a turn off valve at the water heater. You'll have to turn it off at the meter. Gas co will turn it back on when you're ready and make sure you don't have leaks.
The soap water is standard and is in the directions. I'm not sure on the plastic vent, I always go with metal
dolor et pavor
Copyright
Old 02-24-2020, 02:50 PM
Send a message via AIM to fintstone
Soapy water? You guys don't use a lighter or match to test for leaks?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-24-2020, 06:05 PM
