Fleabit peanut monkey
Bob Kontak's Avatar
Escalade warped rotors (boat hauling) Suggestions
Navigator and Escalade for this guy have both ended in warped rotors from hauling a boat.
Local old school FLAPS owner says get the racing rotors at Summit as he has sent a few customers that way.
Any suggestions as to a type or brand that may withstand heat better?
1981 911SC Targa
Old 03-25-2020, 08:07 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
How do you warp the rotors from towing something? Riding the brakes the entire time? If so I suggest swapping out the faulty component between the wheel and the front seat as new rotors will likely need replacement again in short order...
Old 03-25-2020, 08:22 AM
Bob Kontak's Avatar
That would be the steering wheel.
I hear you and texted him just what you said.
I argued with him on the Navigator that rotors don't usually warp but dial indicator confirmed they were.
1981 911SC Targa
Old 03-25-2020, 08:26 AM
Platinum Member
dad911's Avatar
Hills and ramps, teach him to engine brake and use low gears.
Towing trailer down the hill at Watkins, low gear greatly reduces brakes.....
Old 03-25-2020, 08:30 AM
Is it a big boat? Trailer brakes?
Brent
Old 03-25-2020, 08:41 AM
Maybe when backing his boat and trailer down the access...he goes far enough to get the very hot rotors in the cold water.
Just my guess.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-25-2020, 08:58 AM
Bob Kontak's Avatar
8,000 lubs
Firing these questions to him.
1981 911SC Targa
Old 03-25-2020, 09:05 AM
Bob Kontak's Avatar
Trailer brakes?
"I have surge brakes that work kinda half-assed" (Hmmmmm)
Just my guess.
Rear tires in water only. Not even deep enough to touch rotors.
1981 911SC Targa
Old 03-25-2020, 09:13 AM
908/930's Avatar
Have him fix the trailer brakes.
Old 03-25-2020, 09:16 AM
Bob Kontak's Avatar
Has to be a significant contributor.
1981 911SC Targa
Old 03-25-2020, 09:19 AM
908/930's Avatar
He could always just get a larger truck, possibly a Freightliner.
Old 03-25-2020, 09:25 AM
Still Doin Time
asphaltgambler's Avatar
Bob - are his trailer brakes of the surge variety?
Old 03-25-2020, 09:38 AM
908/930's Avatar
Is this truck driven every day? Just thinking if it sits outside for a long time unused could be moisture under pads corroding the discs.
Old 03-25-2020, 10:04 AM
Did he remember to take the pin out after backing it in so they actually work?
Brent
Old 03-25-2020, 10:30 AM
Bob Kontak's Avatar
Originally Posted by afterburn 549 View Post
1, Surge brakes suck, you something a LOT better.
Yes, surge brakes.
This relates to surge brakes?
1981 911SC Targa
Old 03-25-2020, 10:50 AM
Bob Kontak's Avatar
He's well over 85% weight capacity.
1981 911SC Targa
Old 03-25-2020, 10:52 AM
Still Doin Time
Surge brakes are the worst. Some though needs to look at the trailer brakes, adjustment and how much load is placed on the master cylinder pushrod. Thinking you can adjust that, if I remember correctly.
Old 03-25-2020, 11:29 AM
Yep I know he had surge brakes. He needs to switch to electronic brakes with a controller on the dashboard.
Old 03-25-2020, 11:31 AM
Yes, surge brakes.
Yes, most have a pin you put in so you can back the trailer up your driveway and such without the brakes engaging. Otherwise you are fighting the brakes when trying to park the trailer.
Most vehicles with the tow package are easy to put proper brakes on the trailer as well.
Brent
Old 03-25-2020, 12:42 PM
canna change law physics
red-beard's Avatar
Rotors warp with differential cooling. You need to cool them down before you park. I learned that with an Explorer (auto transmission) on the Grapevine. We stopped at a rest area 3/4 the way down. The rotors were hot and when we stopped, the brake pads prevented proper cooling. Had to pull into a brake shop in Bakersfield to get them turned.
James
Red-beard for President, 2020
Old 03-25-2020, 12:53 PM
