Iridium plug gap question
So, I am trying to be a carguy (Vash, you bastard, you inspired me again) and decided to change my plugs, clean the MFI and throttle body on my 5 gen 4 runner. It has close to 90,000 on it. After a few hoses and some swearing out of the way, I discovered that my original plugs are different from the number they gave me at the parts house. According the Denso catalogue on line, the plugs are correct from the parts store. I looked it up and the gap difference is 1mm vs 1.1mm. I know there's no gaping it on my own with these iridium plugs. What do you think, those of you that has experience with "modern" vehicles? I am temped to just put em' on. Ones I got has the larger gap, .1mm
Old 04-10-2020, 06:20 PM
RETIRED
Joe Bob's Avatar
Waste of money.....use the Bosch copper or NGK.
2012 ML350 3.0 Turbo Diesel
Old 04-10-2020, 06:41 PM
I figure that I use stock parts?
Old 04-10-2020, 06:44 PM
Did you get the memo?
onewhippedpuppy's Avatar
I wouldn't sweat it, install them as is. If you try to gap the iridium plugs you'll ruin them.
‘07 Mazda RX8-8
Old 04-10-2020, 07:20 PM
Make Bruins Great Again
Por_sha911's Avatar
For an air cooled 911 - yes. For a modern vehicle - no.
+1 to NOT changing the gap on Iridium.
Joe
Old 04-10-2020, 07:32 PM
Oh no, I wouldn't even try. Its twin plugged in my 930, the others, I have not looked. No can't do without a lift
Old 04-10-2020, 07:36 PM
Thanks. That was what I was thinking too.
DanielDudley's Avatar
Gaps never get smaller over time.
Old 04-11-2020, 06:52 AM
Por_sha911's Avatar
Unless something is banging against the electrode and shouldn't be.
Joe
Old 04-11-2020, 07:57 AM
908/930's Avatar
.1mm or .004" would not worry about it, the ignition system can probably arc across 6mm gap.
Old 04-11-2020, 11:13 AM
