Evil Genius
How do a clone a PC Harddrive?
I've got a 10 year old PC and the hard-drive is going out.
Stays in a state of 100% read/write utilization even when PC is at idle. I recently lost some sector/tracks and some software application I cannot access anymore . How can I clone the installed software over to a new hard-drive? I've got installed software that I no longer have the installation disks for, such as CAD programs and Photo Editing. am I screwed ? I figure if this was easy, it'd be all over software piracy violations. hate to lose some app's.
Life is a big ocean to swim in. Wag more, bark less.
Try ezgig from apricorn
https://apricorn.com/notebook-hdd-upgrade-kits/ I bought one of these over a decade ago and it never failed me. $29 |
The Unsettler
Depends on the individual application.
Often times we tie licensing to a hardware ID. Every component in your PC, hard drive, network card, cd-rom, etc... has a unique identifier that the licensing is tied to. When the software boots up it looks for that piece of hardware and if it does not find it assumes the software has been moved / copied outside it's EULA. Most commonly it's the hard drive but hey they sometimes fail so if we want to be nice we can tag multiple devices and say if 2 of 3 are present then it's all good. That let's you replace a hard drive and not worry about the license. So, are you screwed, probably but not completely.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
To answer the cloning question, the new drive *might* have cloning software included. I bought a Samsung SSD drive and it had a free version of Macrium Reflect, which is what I would suggest anyways.
1) Buy a 500GB to 1TB SSD drive. 2) Max your RAM (you probably did with CAD) 3) Buy a $40 graphics card 4) ? 5) Profit from a much faster computer.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Formerly bb80sc
Macrium Reflect...easy
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Or, for under $30 you could get one of these. Also works as an external enclosure. I use our a lot as we upgrade machines. Put a 6TB drive in the HTPS, use the old 3TB drive in my gaming computer, use my old 2TB in the boy's unit, etc. Only had one issue where I had to re-clone and that was because the power went off.
https://www.newegg.com/wavlink-wl-st334u-dock/p/0VN-0069-00001?Description=clone%20hard%20drive&cm_re=clone_hard_drive-_-9SIA6PF3NA0586-_-Product&quicklink=true
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
canna change law physics
I use Acronis True Image - I think it came with a Kingston drive a few years ago.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
To recover files from a damaged disk/filesystem, PhotoRec/TestDisk, ddrescue.
To simply clone, CloneZilla. All free downloads; boot from a USB stick or burn a CD. Ultimate Boot CD packages a bunch of those and many other free utilities. https://www.ultimatebootcd.com/
'77 S with '78 930 power and a few other things. |
That actually might have been what came with my Samsung drive as well, instead of Macreum.
Does OP know what to do?
You buy a 2nd drive, connect both to the same PC and then use one of the tools mentioned above to do a drive copy. Then you only leave the new drive plugged in. Swap complete. YouTube should have tutorials
1986 Bosch Icon Wipers coupe. |
