vash's Avatar
Originally Posted by fastfredracing View Post
Thanks for the replies, and offers guys, I am building a 20x40 quonset hut garage at my house . Im going to try to do it all myself . Dig , form, and pour the footer, pour the pads, and erect the building Im thinking about doing the floor in 4 smaller pours .
I did some smaller pads this spring to get a feel for how much concrete I think I could handle single handed.
I have string and a 4 foot level, but a friend who is not a knucklehead, could be a tough one . Im using my 14 year old for cheap labor .
Apologies for the knucklehead comment. I have a coworker that will pull the end of the tape measure out Leaving me with the end to read the length. I can ask him, “well what do you have?’” He will without fail look down at the tape measure in his hands and ponder it.
poof! gone
Old 05-27-2020, 07:07 PM
A930Rocket's Avatar
When measuring something, we always say do you want the smart end or the dumb end.
Old 05-27-2020, 07:11 PM
wayner's Avatar
The biggest problem with quonset huts seems to be making the metal to concrete joint water tight.
Dont rely on silicon sealant (I wouldn't use it at all). Instead, look into roofing or window flashing materials and sealants.
I would squish something like butyl flashing in between as a gasket.
I live in snow country. If you do too I'd also do the same where the wall meets the sill plate
SOLD - 914 wide body hot rod
Old 05-27-2020, 07:24 PM
vash's Avatar
Consider the phrase stolen.
poof! gone
Old 05-27-2020, 07:44 PM
UnRegistered User
billybek's Avatar
And if you are holding the dumb end, pull the end a few inches past the point and watch the games begin....
Bill K.
Old 05-27-2020, 08:37 PM
Brew Master
cabmandone's Avatar
Lookup monolithic foundation. Then get a few friends that like to drink when the job is done and have at it!
Nick
Old 05-28-2020, 01:26 PM
You do not have permissi
john70t's Avatar
Make sure there is a a water drainage slope to it. Somewhere to a side area or a pit.
Always a sloped drain for that ice in the middle of winter.
If there are chemicals and grease involved, you will want to install an "easy to clean" grease trap/more and not poison the neighbor's ground water or your own family.
You could spray off those really nasty vehicles first quickly and be able to work on clean material.
Before any big pour you might consider some sort of in-floor heating. Maybe electric and/or antifreeze lines powered by solar panels+.
Also a few sloped PVC conduits with capped up-spouts located a foot away from the foundation.
Good for power washer water hose, air hose, more electric lines for night lighting, or additional communication lines.
Old 05-28-2020, 05:35 PM
DanielDudley's Avatar
Fred, a string level is notoriously inaccurate. The longer the string is, the more it bows, and the level will tilt if it isn't exactly in the middle of the string. I prefer a self leveling lazer, which can be had for less than 100 bucks. It works like a rotary, but you have to position the beam by hand.
If you use a string level, just put it in the middle of the string, and follow up with a 4 foot level on the deck to verify you aren't way off. Decks don't have to be perfectly level to build off of, as long as they are flat.
Old 05-29-2020, 02:51 AM
vash's Avatar
okay FASTfred. you're pouring a big pad. i get it.
i think you can do it with your 4-foot level and a long ass straight edge. you are gonna have to form up the pad anyways. you wont pour 20x40 in one big pad. you are limited by the length of your screed. say it is a 12 footer. you would set intermediate forms (batter boards?) at 10 feet that way your screed has a board it can ride on. these boards are what need to be level. get those perfect with a good long straight edge, (we have aluminum ones in the office) with your regular bubble level on it, and pour it in 10 foot wide sections. then you pull the intermediate batter boards and level off the seam.
boom!
poof! gone
Old 05-29-2020, 08:35 AM
vash's Avatar
you are not doing it solo by the way. pulling a screed needs a few people. one guy with a shovel dumping extra mud in the dips, and two guys pulling the screed. minimum.
i seen guys pour 7 lane wide bridge decks. it is an event and a half. huge teams of laborers. awesome one. one day, i am gonna kidnap a group of them and make them do my driveway.
poof! gone
Old 05-29-2020, 08:36 AM
fastfredracing's Avatar
Yes, I was going to do the pad in 4 pours, as I think 10 x20 is just about as much as I can handle in one shot. . I will have my son, and a helper for the pours .
I was going to do the footers, erect the building, then pour the pads . I have to be able to work around Pa weather, and reality is, that Ill be lucky be done by fall, most likely , Ill still be doing concrete in the spring .
I am going to need about 4 guys to stand up the first few arches. I honestly , believe that I can do the rest from there solo or with my sons help
Good thing is, I declined on that house that I looked at, so my free time is still wide open .
Thanks for all the advice . I think I am going to grab up a lazer level anyhow, cool tool to add to the stash ...
Tell me if I am wrong though. I am assuming , I should have the floor of the ditches as level as possible before I start dumping stone in , correct?
This one is all you tube universtiy , and Ill probably ask lots of questions here .
And Vash, you are all good . One of the coolest guys on the forums . I don't think you've ever offended anyone here . I took zero offense to the knucklehead comment. It was funny
Really appreciate the advice . I am going to try and obtain a permit in the next few weeks, and its game on .
No left turn un stoned
Old 05-29-2020, 09:22 AM
908/930's Avatar
Have you tried to get a price for a crew just to place the concrete for the pad? Do the footings and forms yourself, level and put in vapour barrier and rebar+heating tubes( if using) Slugging concrete is hard work, and you will prob need to rent a power trowel. Labour is expensive out here and I think they charged me about $1k ($600us) for about the same surface area. You will probably get hit with a fee for less than full truckload, (check that) do that four times and will pay for part of the crew.
Old 05-29-2020, 10:14 AM
Brew Master
cabmandone's Avatar
Fred,
You can rent a rotary laser for your job. Just get it and the MINI Excavator at the same time. I have a friend in Mt Pleasant PA that I could talk to about making you a deal on the rental of the mini!
Nick
Old 05-29-2020, 12:57 PM
Originally Posted by cabmando View Post
Fred,
Thank you for the offer. I have a big old MF backhoe, Actually 2 of them. And an operator to go with it !
Its one of the best tools I have ever purchased. I have done so much work with it over the years. Probably saved me twice its cost in equipment rentals
Old 05-29-2020, 01:09 PM
What kind of finish are you looking for on the floor?
If looking for anything close to smooth you better have at least one guy that can finish concrete. This was the crew that placed and finished my workshop slab.
Old 05-29-2020, 01:28 PM
I was actually planning on purchasing a power trowel . I see them used all the time for around 500.00
I was kind of surprised how well the few pads I hand troweled turned out. I think I could pull off a decent job by hand if wanted to , but man, that is a lot of work when you are talking about that much area .
Old 05-29-2020, 02:51 PM
Brew Master
cabmandone's Avatar
NICE! Teach em' right on the old 4 handle stuff! That's what I learned on too.
Nick
Old 05-29-2020, 02:59 PM
