How long do transformers last
I wired a buck boost transformer to go from 208V to 230V for the air compressor. Has worked perfectly for 5 years. Stopped working the other day. Have compressor in the 208 outlet now.
Do they have a fixed life? Is 5 years of constant use (most days compressor runs to fill up at least 30 times) considered normal?
Tru6 Restoration & Design |
Are they hour rated, or cycle rated??
dolor et pavor Copyright |
I will have to look at the documentation this weekend.
Sized correctly they last forever, well close. Was it large enough for the starting load? Is your motor failing and drawing more amperage?
87 930, |
Depends on the transformer, I guess. I have an old "transformer powered" desk lamp I bought in the early 60's 110 to 12v, uses a #1156 automotive tail light bulb.
It's lighting my keyboard as I type...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Look closely because most transformers are more than meets the eye.
DeWalt 5-HP 80-Gallon Two-Stage Air Compressor (230V 1-Phase)
Home of the Whopper
Environmental conditions matter too.
Transformers give off heat and can get dirty. How hot did it get? Where was it located?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
How did it fail? Shorted? No continuity on primary or secondary side?
I only know about guitar amp transformers, but they pretty much last forever if treated properly. That means the impedance or load has to always be correct. A tube shorting out can kill it. As long as it's running properly, it should not be putting out much heat, which means it could be covered in dirt, dust and debris and still run fine. But have a mismatch in impedance, and it's gonna end badly. Just had this happen on a 1979 Marshall 100w head I have ridden hard and put away wet. A bad tube is what killed it. Otherwise, the power tranny was going to last forever.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Optimus Prime engaged in the battle of Sherma Bridge with Megatron about 4 million years ago. So he's probably 4-6 million years old.
-mike |
As others have said, a failed transformer is often a symptom of another problem. Arcing motor, over-current or some other issue likely killed it.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Mike knows what’s up
Background. 208V outlet was put in when I was doing the children's clothing years ago for the silkscreen equipment and clothes dryer. Getting the 230V Dewalt compressor I got this transformer:
ACME T181052 Acme, Buck Boost Transformer, 12/24V 750va Because I needed the dryer to work (cleaning polishing fleece blankets), I mounted the transformer on the wall and added a dryer extension cord and an outlet to it. For 5 years the compressor is plugged into the transformer outlet. Then the the transformer and dryer were alternately plugged into the 208V wall outlet. Just did some testing. Wall outlet is putting out 212V Transformer outlet is putting out 96V. Enough for the dryer to work off it (just as a test) but not enough for the compressor. I can take the cover off the transformer end of the day to inspect. Environment is essentially office space. Clean, dry.
^^^^ That s your problem there, you bought it from Wile E. Coyote supplier. There stuff never works as expected!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
try again to find the correct transformer
208 is a three phase configuration, that is a single phase transformer the output on that transformer should be about 24v at 240v input
Chris the more i learn, the less i know |
UnRegistered User
Transformers are smoke encapsulated.
Letting the smoke out seriously limits their ability to transform...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Platinum Member
Shaun - I have the specs/connections opened up in a PDF. I suspect you have it wired like this: ![]() If so, voltage measured should be approx: Input 212v(as measured) H4-H3 - 106v H2-H1 - 106v X4-X3 - 12v X2-X1 - 12v If not wired like that, post the wiring and the voltages measured.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 06-06-2020 at 08:27 AM.. |
Thanks Dad, I won't be able to pull it apart today but will tomorrow.
If I wired it incorrectly, would it still work for 5 years and then fail?
Platinum Member
I'm hoping it's one of the 12v secondaries(which isn't a deal killer), or a loose connection. The PDF states a 10 year warranty. FWIW
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 06-06-2020 at 10:14 AM.. |
