Spoon ID help
Can anyone ID these two rifles? Both are similar though the one with the stand has some chinese writing.
1982 911 Targa, 3.0L ROW with Webers
Old 06-12-2020, 02:21 PM
varmint's Avatar
Arisaka?
Is there a mark that looks like a chrysanthemum on the breech?
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 06-12-2020, 02:27 PM
varmint's Avatar
The top one is a moisin. nagant. There are a thousand variants. A few quite valuable,
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 06-12-2020, 02:31 PM
Top one is a Russian Moisen Nagant, bottom is a Japanese Arisaka Type 99. Both were commonly used in the Ballard Infantry.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 06-12-2020, 02:37 PM
Not seeing the logo, but i did look up the arisaki and realized I also have the bayonet for it.
Old 06-12-2020, 02:38 PM
Thank you for the information! Further googling lines up exactly with what you said.
Old 06-12-2020, 03:17 PM
fred cook's Avatar
The Moisin Nagant shoots the 7.62x54 rimmed (Russian) cartridge. Easy to find and relatively cheap.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-12-2020, 03:59 PM
I think one was issued to Sven, the other one to Ollie.
Jeff
'72 911T 3.0 MFI
Old 06-12-2020, 04:45 PM
What did they issue to the Magnolia branch? Something with a little more polish I assume.
I do appreciate the assistance, I had absolutely no idea what to even look up.
Old 06-12-2020, 04:55 PM
No doubt the finest Holland and Holland "Royal Grade" double, of course.
My pleasure. If you don't mind my asking, how did you happen into these things?
Jeff
'72 911T 3.0 MFI
Old 06-12-2020, 05:24 PM
Arizona_928's Avatar
The mosin nagant is a m44. 1960 manufactured year obviously. It is Eastern European. Romanian, Polish, or Hungarian. Would need better pictures to positively id.
If you're interested in selling. I have a 03 FFL.
dolor et pavor
Copyright
Old 06-12-2020, 05:29 PM
I believe my dad brought them home from Vietnam. I had seen one of them as a child but then not again until yesterday. I was working on cleaning out his shop and found them hidden. Probably been in the same spot for 25yrs.
Not selling due to the connection with my father.
Old 06-12-2020, 05:46 PM
fred cook's Avatar
Arisaka
The Japanese rifle would have had a Chrysanthemum with 7 leaves on the top of the receiver where the ground spot is located. In many cases the "mum" was ground off when the rifle was surrendered. It would be either a 6.5mm or 7mm caliber. The little "legs" that fold out on each side of the rear sight are for leading aircraft when trying to shoot the plane down! Both of the rifles could use a good coat of oil.
FEC3
Old 06-12-2020, 08:13 PM
Thank you for the additional info! They will definitely need some TLC if not some professional attention which they probably deserve.
Old 06-12-2020, 08:18 PM
I'm sure they will both clean up nicely. Depending on the care lavished before they were stored, they may even shoot acceptably. Neither is a "target" arm, or course, but both earned respect as very capable battle rifles. If the bores were suitably coated with some form of oil or preservative, they might be great good fun to take out and do a bit of shooting. Unless there is really obvious damage or structural corrosion, both should be safe enough with proper ammunition. I believe both calibers are still at least somewhat available, even if it takes a bit of looking to find them. They could both bring new meaning to those "Free Ballard!" bumper stickers...
Jeff
'72 911T 3.0 MFI
Old 06-12-2020, 08:36 PM
