I need a tool for this splitter
![]() These solid brass hose splitters are sturdy and last forever, but MrsWD has a ot of trouble turning them off and on. She needs some kind of tool to give her better purchase and/or better leverage. I've seen tools that are essentially a cylinder with a slot cut in it at the end of a screwdriver handle. Something like that would work. I don't know what to call the tool or where to find one. If I had a milling machine I'd cut a slot in a 1/2" nut driver and be done with it.
Retired, finally
Vicegrips?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Just make a little wooden handle with a slot/oval to fit around those knobs....mebbe an old wooden hammer handle, etc.
A flat piece of steel and cut a slot in it . Or find an old socket of the correct diameter and cut slots in it .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Adjustable wrench on a tether.
Tack weld the adjustment, plastidip it. Done.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Here's a quick sketch for the easiest tool if you have some woodworking equipment and no metalworking equipment. Take a piece of wood, cut a slot the width of the valve knob (shown in black) and then drill a hole near the end through the sides and put a bolt with nut (shown in gray) to keep the slot from splitting.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Platinum Member
Old socket and grind 2 notches for the ears?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Brew Master
It's a magical tool called a "channel lock"
BTW, you don't need a milling machine. Just need a grinder and BAM! new tool. Or you could take a box end wrench that's just a bit too small, heat it and beat it into an oval shape that fits the handle. OR! You could take those handle off and go buy lever type handles for it. All good options.
Nick Last edited by cabmandone; 08-11-2020 at 06:12 AM.. |
Here's another option - plumbing socket option - cut slots in opposing sides of the best fit socket:
I recently bought a splitter like that, only with four outlets. It came with plastic handle covers to give us more leverage. My wife has no issues using them.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Unregistered
Under four bux on amazon, you might need to file the opening a little to fit.
https://www.amazon.com/Ready-America-3333-Earthquake-Emergency/dp/B000BQKLWK/ref=sr_1_2?dchild=1&keywords=gas+shutoff+tool&qid=1597153750&sr=8-2
Edministrator
Good post? Leave a tip! O - $1 O - $2 O - $3 |
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
i thought they make a spanner wrench that fits those?
poof! gone |
You do not have permissi
pop the handles off and grease them with eco-friendly.
Meanwhile other things are still happening. |
Almost Banned Once
Brass fittings are great but something like this would be better for your wife.
Still decent but easier to use.
- Peter |
Clearly, you either need to buy a 3D printer and then print some overly complicated handles.
Or you could CAD up some handles and then send the files to a company that does CNC milling to have them made for you, preferably out of something like titanium or a specialized alloy, and then have them coated/treated for extra durability and weather resistance. You're welcome. I'm just trying to provide the simplest, most cost effective solution for your problem.
i bet the emergency gas shut off tool will fit.
poof! gone |
Water valve wrench
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
