A930Rocket's Avatar
Wireless security cameras?
What’s the latest and greatest in wireless security cameras?
I have the Blink system I brought from our old house, but for the life of me, I can get it to connect with our WiFi system. Same router, modem, password, etc. but no dice. It shows the correct password, but it just won’t accept it and I’ve tried eleventy hundred times.
So, I’m thinking it’s just old and I’ll get a new Blink system. Took a look and prices are higher than three years ago.
So, what everyone is using now?
Edit: any advice on getting the old system working?
Old 09-13-2020, 05:44 PM
Have you tried deleting the camera from the computer and re-installing?
I've had to do that with my Nest Cams once...fixed the problem.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 09-13-2020, 05:59 PM
I will be getting that Arlo Pro 3 soon.
Here is the thread:
http://forums.pelicanparts.com/off-topic-discussions/1061721-security-camera-questions.html
Old 09-13-2020, 06:15 PM
Driver, not Mechanic
There must be a way to reset the Blink camera.
If it were me, I'd get an Arlo Pro 3.
Old 09-13-2020, 06:18 PM
A930Rocket's Avatar
I’ve reset and unplugged/plugged in the synch every time I try to re-install it. I get the blue/green flashing light, select my WiFi and enter the password. The synch module light turns red after 20-30 seconds and game over.
One question I have is how do I pick the 2.4 or 5.0 ghz(?) WiFi. Looking at my phone, it doesn’t give me an option, but I see it on the router. It’s just one name. Could this be the problem?
I’ll also unplug/plug in both the router and synch module tomorrow to see what happens.
I have four cameras, so I’m not ready to give up yet and spend $3-400 clams.
Old 09-13-2020, 06:51 PM
jyl jyl is online now
jyl's Avatar
I had that problem recently. Just kept trying. Took like ten ! tries. Never did figure out what the issue was. Hasn’t recurred.
Old 09-13-2020, 07:13 PM
biosurfer1's Avatar
2.4 and 5 will have different SSID's. They might have a similar name but it's usually something like "A930RocketWIFI2.4" and "A930RocketWIFI5.0".
A device only capable of 2.4 wont see a 5.0 SSID so that shouldn't be a problem.
Old 09-13-2020, 07:15 PM
A930Rocket's Avatar
Blink FAQ’s says the password is usually the problem, but I just reset my phone and laptop, so the password is good.
I find it hard to believe I can enter the password wrong that many times. Especially when it shows the correct password. 🤬🤬🤬
The real reason I’m looking at them again, is because my wife’s Tahoe was broken into the other night. One of two in the neighborhood. They took some CD’s and her moms handicap placard.
Old 09-13-2020, 07:21 PM
Vintage Owner
Jack Stands's Avatar
I’ve been happy with the Wyze cameras. They’re inexpensive and have clearer Video than the wired system at my office.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 09-13-2020, 07:44 PM
Recreational Mechanic
Nickshu's Avatar
I'm using Ring. Very happy with the setup. Have 6 cameras so far mostly outdoors.
Sent from my Galaxy S20+ using Tapatalk
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 09-13-2020, 08:01 PM
Unless you named the 2.4 and 5Ghz differently, it would be the same ssid. It will automatically connect to the stronger signal. (2.4 the farther from the WiFi base.)
Are you sure you are typing your password correctly? Have you tried connecting anything else new?
Old 09-13-2020, 08:14 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
I have the Ring system. 3 cameras so far, each bought when they have one of the deals running.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 09-14-2020, 01:11 AM
It usually takes eleventy hundred and 3 dozen tries!
Try "hard selecting" anything that might be negotiating between the two, renaming the SSIDs, device names, etc.
Cuss at them both
Good luck!
Old 09-14-2020, 03:50 AM
The Unsettler
stomachmonkey's Avatar
Since you are trying to connect to the "old" network and not succeeding try renaming the SSID's and set everything up from scratch.
Last week I spent 3 days trying to fix something that should have been an easy fix.
Got up Saturday morning and said **** it, started from scratch. Was done in 2 hours and problem gone.
Sometimes trying to fix stuff is the long way around.
"I want my two dollars"
"Brandon Won"
Old 09-14-2020, 10:28 AM
300hp 1800lbs is the goal
pksystems's Avatar
I have 5 wyze cams. If they had the ability to be viewed from a desktop, they would be perfect.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 09-14-2020, 10:30 AM
Still here
pmax's Avatar
Not sure I would want video and audio feeds from my home being sent to some random server somewhere out there in the Interweb perhaps even in one of your favorite countries overseas.
No one here have any concerns about privacy ?
Old 09-14-2020, 01:54 PM
This.
Highly doubtful that your cameras quit working in the move.
Delete everything...start from scratch.
98 Honda Prelude
22 Honda Civic SI
Old 09-14-2020, 02:00 PM
A930Rocket's Avatar
This.
BRDT, but I’m going to try everything again tomorrow....delete the app, reinstall, unplug/plug in router and synch module, new system name and hope it works.
If it doesn’t, I’ll be forced to read the directions or contact Blink...
Old 09-14-2020, 07:16 PM
Still here
pmax's Avatar
Are you sure they didn't get hacked ?
These devices are notorious for their lack of security.
Old 09-15-2020, 12:45 AM
Been outta the game a long time... but it isn't magic. Start from scratch and KISS, renaming, etc. until you pinpoint where in the "hand shake"... you're getting a middle finger instead? Oh yeah... can't you ask yer kid for help ?
Make sure you're resetting all devices back to "factory defaults"... so nothing is cached, etc. Good luck!
Old 09-15-2020, 04:21 AM
