I just tried detecting a small powerful magnet through 1/4 aluminium with a small compass, can easily point to it from 4 inches away. Pretty low tec but better then getting arrested trying to buy a cobalt 60 source to shoot a X ray, LOL.
87 930, Last edited by 908/930; 01-15-2021 at 07:44 PM.. |
Ultrasound could probably give you a decent enough image for what you’re trying to accomplish. I hear what you’re saying about the x-ray detector positioning, but I don’t think that’d be an issue. There are portable X-rays that are strong enough to penetrate through very dense/thick materials and could penetrate through a section of fiberglass, wood, and stainless sheet metal. Take an image from the top down to get your cross-car and fore/aft location, and then an image from the side view to get your up/down position. |
I like this idea better than X-ray, it’s simple.
Author of "101 Projects"
Okay, so I just spent some time in the garage. The tool of the day? High powered magnet!
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
![]() -Wayne
I did build a unit years ago to hold a x ray head and a detector, I could check if it is still in use. It was intended for medical imaging but should work. It was bolted to a gamma knife though, could be a problem getting over the border.
87 930, |
If you are drilling into a fibreglass wheel well couldn't you use a tank cutter to make a large enough hole to facilitate easy access to the pipe connection, and glass it up afterwards?
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
There is a way to use some basic carpentry tools and a little measuring and layout work to determine a point directly below the outlet that would be a good starting point for an investigative access hole to be drilled. It would take an hour for me to type it all but if you want to try it, let me know and I'll work on it.
Local help available
First time forum post.
Was sent here by fellow gear-head driving buddy, because of my boat repair and fiberglassing experience. First: Really cool project, love the look and the history behind it. Second: Boatbuilding 101. Polyester resin (without a doubt), chopped strand mat, urethane foam and wood. So the exploratory surgery tool here is a 1.25 inch hole saw, but one that has grinding grit on it, not teeth. This makes small enough holes for visibility, that can then be easily re-glassed back over, and the circles are small enough (and strategically placed) so the don’t effect structural integrity. OK, I hate this part because it feels so immodest. I have been doing fiberglass repairs as a tinkering hobby for 15-20 years. I work as a Manufacturing Engineer for a major aerospace company, specializing in Composite fab and repair. I have taught a Composite fab shop class at a local SoCal junior college (wet layup and prepress) since 2001, so have lots of sources and connections. I would love to come by (safety protocols of course) and take a look and help on a volunteer basis, cause this is such a cool and unusual project. (I cut my teeth on aircooled VW’s but have moved on to Datsun roadster canyon carver) When I learn how to Private Message I will send along contact info. I commute daily from Seal Beach to El Segundo, so am around in the area regularly. Sorry for the long post. Fergus O |
Use a water level to determine elevation of tank outlet
Wayne, Since the outlet of the tank shown in the video is on the vertical wall of the tank, use a water level to determine the exact elevation of the tank outlet at the area you circled in red on your photo. The one tank shown in the video shows that the line from the tank to the pump comes from below the tank. One of your photos appears to show the other tank feed comes to a pump in the engine bay. Is that correct? If so this would not work on that tank. Either way consider using a water level. Very simple but is accurate and handy. To get the centerline elevation of the tank, fill the tank to the center line of the tank outlet. Water level explained: https://en.wikipedia.org/wiki/Water_level_(device) |
The datum line should be the centerline of the tank sending unit opening, or some other reference point. Last edited by kmoush; 01-16-2021 at 11:32 AM.. |
He doesn’t need a laser level, he just needs a framing square, a tape measure, a plumb bob, some string and a sharpie.
Gotta love Amazon, I still don't see how they can do it. This was $100 with a random $30 coupon at checkout. Ordered last night at about 7:30PM. On it's way here today. It will probably be here before I even get my newspaper today! ![]() This thing got really good reviews, and the reviews span a year or two, so they are not likely to be fake... -Wayne
The real big clue is the high powered magnet is sticking right under the spot where I would imagine a hose clamp to be. I did an additional test where I took a hose clamp and put it on the inside of the fender and took the magnet and tested it on the outside, and it felt similar / the same. So, I'm very hopeful that the connection that I'm looking for is right there.
Again, I will do this later on today: - Clip the gas line on the left side of the car (no going back after that). - Thread a pipe cleaner / wire through the gas line and into the tank. I will look inside the tank to see the pipe cleaner come through. - Then I will thread some string through the hose, so that one end of the string will be sticking out of the outlet in the tank, and one end will be out of the other side of the hose. This will allow me to "keep the path intact" on the current hose in case there is difficulty threading something in the future. - Then I will stick the camera down that hole (I hope the radiator is not in the way, the area on the left side of the car seems to have a bit less access than the right side - perhaps I should do the right side first, although that outlet port appears to be clogged with old varnish / gas). - The camera images should give more clarity on the path and what's in there. A few smart people suggested something I hadn't thought of before. Just forget about the gas tanks on the sides and install a larger fuel cell / racing style one in the rear trunk. That's not a bad idea, and we have that in our Mercedes 190 SLR Roadster, but I would like to keep this Probe as original as I can at this moment. Something like this: Also thank you if you sent me an email - I literally have about 35 long emails in my inbox, and I will respond to every single one, probably after I do this new camera inspection... Thx, Wayne
i didnt read much but id cut the line and shove it in you should be able to get somewhere like that. As for an access hole is there no way to get at it from the cabin down low? Then you dont have to mess with body work or questionable access at the wheel wells
82 SC , 72 914 |
I'm as perplexed about this as anyone. However, after reading about the wire/string idea, I thought I'd share this: when rewiring an old lamp or light fixture with a lot of curves in the tubing supporting the sockets, I use a long lamp chain and a vacuum to get a pull wire in there.
It's already been mentioned that a flexible cable like a bicycle brake cable will have the strength to pull. The lamp chain will break with not much force but it will go around some pretty tight and complicated lamp designs. There are many lubes for these projects so I'll leave it at that. |
Yes, it is confusing. There's no access from the cockpit - it's one solid / melded form of wood.
Here's a drawing from the rear: ![]() -Wayne
Platinum Member
Can you put a bulkhead fitting in a more accessible area and run a new line? Something that would also be serviceable later. Near the filler or sender?
Or are you trying to maintain originality?
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk |
