-   -   Adams Probe 16 Restoration Project... (http://forums.pelicanparts.com/off-topic-discussions/1074841-adams-probe-16-restoration-project.html)
javadog 09-04-2021 04:45 PM
Once in a while I have had occasion to do something similar to a fuel tank and I generally use a small outdoor fountain pump. Thus far, I haven’t clogged one up or ruined one.
javadog 09-04-2021 04:47 PM
When I’ve had to do something similar in the past to a fuel tank, I used a small outdoor fountain pump. Thus far, I haven’t clogged one up or ruined one. It’s also what I use to clean metal fuel lines.
Wayne 962 09-04-2021 04:49 PM
I thought about using an old bilge pump I have lying around, but to be honest, I couldn't find it within five min of looking, so I just used this fuel pump we had lying around.
-Wayne
Wayne 962 10-26-2022 07:05 PM
Still working on this thing. Here's what's happened:
- Cleaned the tanks, the solvent worked well, although I also used it on something else (non-stainless) and it dissolved that!
- Engine is out and at Mountune being rebuilt
- New seals came in this week.
- New tires (good luck finding 12" performance tires! - that was difficult)
- Re-ran the heater hose lines through the center
- Replaced all the fuel lines
- Realized the fuel pumps were shot, so I replaced those with modern ones.
- Finished up the brakes - had to replace nearly 100% of the components
- Electrical - still had some issues, I fixed those.
- Suspension - finally ordered the (custom) new shocks from England and got them delivered and installed
Working on the interior and the engine bay tonight!
Photos here...
-Wayne
http://forums.pelicanparts.com/uploa...1666836233.jpg
Wayne 962 10-26-2022 07:07 PM
More photos:
http://forums.pelicanparts.com/uploa...1666836381.jpg
masraum 10-27-2022 06:08 AM
Excellent! Thanks for the update, Wayne! Such and interesting and odd build.
astrochex 10-27-2022 06:23 AM
Great to see the build is progressing well. Thanks for the update, Wayne.
Wayne 962 10-27-2022 11:22 AM
Yes, that's very accurate!
-Wayne
masraum 10-27-2022 12:49 PM
I can't imagine trying to get "performance" 12" tires. These days anything remotely performance oriented is tough to get it 14" and 15". I have to assume that even going the specialty/designed-for-vintage route when talking about 12" is tough.
It's hard to imagine "175/70R12" being considered performance. I think I've had econoboxes back in the late 80s that ran on 175-75R13 and 175-80R13. And the only "performance" aspect of them was the lack of performance capability.
Wayne 962 10-27-2022 01:01 PM
Indeed, it's all relative. Let me clarify the word "performance" in this context. It means getting a tire wide enough to sort of match the previous Goodyear Rally Special tires that were on there previously. Nearly everything else is a 145 or so width tire which is basically a pizza cutter. I believe that these 175 tires are off of a Ford Cortina?
-Wayne
nota 10-27-2022 01:10 PM
SEEN SUPER WIDE GOLF CART 13X40X8'' and 14x35x8'' no idea if road legal but WIDE
are those 4'' or 100mm bolt circle or 4 1/2''
Wayne 962 10-27-2022 01:13 PM
I spent about 10 hours looking at tires, and those were something I looked at, but I think the speed ratings are low...
I don't remember the bolt circle off the top of my head. But I found the tires, so we're good for now.
-Wayne
nota 10-27-2022 01:13 PM
old MINI maybe used the bitty ones ford cortina was 13'' I think
Tobra 10-27-2022 01:49 PM
Looks like the motor is out of Cortina too, Not the Colin Chapman flavored one.
Dig the color, look like wheels off a Fiat or something, Campagnolo maybe? What size tires do Mini Coopers run?
masraum 10-27-2022 03:16 PM
I think original minis came with 10" and/or 12" wheels and the tiny 145 section width tires that Wayne mentioned.
Tobra 10-27-2022 03:20 PM
I suspect you could get some 13" track tires. When will you ever drive that thing in the rain?
Who balanced those tires for you? All the ugly, stick on weights on the front of the wheel?
I would kick them square in the nuts.
How about some 14" wheels?
LJ851 10-27-2022 04:13 PM
Later Minis use a 165/60 12 and some sporty tires are available in that size.
herr_oberst 10-27-2022 04:35 PM
Alex and the other droogs are so happy you're making such good proggy on the Adams.
Call him when it's ready; likely you can find him having a Moloko plus down at the milk bar, or enjoying a little Ludwig Von at his home with a guest or two!
HarryD 10-27-2022 05:08 PM
http://forums.pelicanparts.com/uploa...1666915690.jpg
Wayne 962 11-08-2022 12:59 PM
More probe progress. Very difficult to install new seals and this trim. What a pain.
http://forums.pelicanparts.com/uploa...1667941079.jpg
