vash's Avatar
electricity comsumption
specs. what does the power consumption mean? i have a 10 amp hour battery.
Nominal Supply Voltage 12 V DC
Operating Voltage Range 10.8 V DC to 15.6 V DC
Power Consumption At Full Brightness 5.3 W RMS
Connections Power / Transducer combined input
Waterproofing Standard IPX6 and IPX7
Display Size 5.0 in
Display Resolution 800 x 480 WVGA
Aspect Ratio 15:9
poof! gone
Old 10-26-2020, 11:30 AM
Most every battery backup and electronic device like to use different measures of the "draw" or consumption and they do that to make the number sound bigger.
So the will change from amps to watts and HP to kilowatts and BTU. First you have to start with a power scale, and convert the rating to the same scale to have an idea of what they are really using.
Like measuring vacuums it starts with PSI and suddenly changes to torr or microns.
Old 10-26-2020, 11:42 AM
canna change law physics
red-beard's Avatar
A 12V, 10 Amp-Hour battery has a nominal 120 Watt-hours of energy
It should last about 120/5.3 = ~22-23 hours.
The reality is the AH rating is at a specific discharge rate, which is usually 20 hours. Which is pretty close to your discharge rate. If you had a larger load, say 20 Watts, the discharge rate is much higher and the energy lost to heating is more. You would probably only get 8-9 Amp-Hours.
James
Red-beard for President, 2020
Old 10-26-2020, 11:46 AM
a 10 amp-hour battery can supply 10 amps for one hour, or 5 amps for 2 hours, or 1 amp for 10 hours, or 0.5 amps for 20 hours.
Watts=Voltage*Amps
5.3=12*Amps Amps=5.3/12=.45 which is close to 0.5 amps
So, the 10 amp-hour battery will last a comfortable 20 hours.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-26-2020, 11:48 AM
red-beard's Avatar
Watts=Voltage*Amps
Sort of...But you need to look at the battery ratings. A 10 amp-hour battery discharging more than 0.5 amps will definitely not have full rating. If you discharge at 6 amps, it will discharge in 1 hour.
See here:
http://files.upgi.com:8086/UPGFileService.svc/GetSpecSheet/D5719
James
Old 10-26-2020, 11:57 AM
vash's Avatar
Watts=Voltage*Amps
thanks. you dumbed it down beautifully.
i cant see needing it for more than 16 hours on the rare occasion i need to use it for two 8-hours stints before recharging. most will be 8 hours.
poof! gone
Old 10-26-2020, 12:58 PM
5 Watts is almost nothing.
Old 10-26-2020, 01:01 PM
Eric Coffey's Avatar
This.
The type (chemistry) and quality of battery factors in. You can have 2 batteries of the same voltage and capacity (AH), and one will do fine at higher loads (high-drain), while the other will drop off a cliff with the same load increase (and potentially be a fire hazard in extremes).
Old 10-26-2020, 01:18 PM
You're welcome. I figured you wanted a down and dirty explanation, rather than a treatise on the inability of modern batteries to maintain power over time
Mike Bradshaw
Old 10-26-2020, 09:08 PM
Platinum Member
dad911's Avatar
Kayak fishing trips away from power?
You can solar charge that 12v battery at a rate equal to or greater than the draw for not alot of money.
Old 10-26-2020, 09:28 PM
Ha! Ha! The slope get's steeper!!!
Marv Evans
'69 911E
Old 10-26-2020, 09:31 PM
red-beard's Avatar
You're welcome
James
Old 10-27-2020, 06:04 AM
red-beard's Avatar
Vash, PM me your address or where you can receive a package.
James
Old 10-27-2020, 06:06 AM
vash's Avatar
you wouldnt happen to have the stuffed squirrel, would you?!
poof! gone
Old 10-27-2020, 01:11 PM
red-beard's Avatar
LOL! Thank God, no.
James
Old 10-27-2020, 08:01 PM
