ceiling fan wattage regulator?
Brain trust, I am sick and tired of the flickering lights in my kids study room. They almost never turn on the light, because they aren't old like me. They see like a cat.
What the heck if this regulator for? Its only hooked up to the lights but nothing to the fan motor? Is that what its celled, regulator? I have power going into it, but nothing coming out, so its deal. My thinking is, I will run two small LED lights into those sockets, the candle looking type bulb off the shelves. Why the heck do I need this dumb thing? What's it regulating? Lawyers want it on there to help my me to have a better, safer life?
Old 11-14-2020, 04:42 PM
wdfifteen's Avatar
Lights should work fine with a rheostat. Motors not so much. They like stepped current (or voltage, not sure which). I can't help you much beyond that.
Old 11-14-2020, 05:07 PM
Is it for a remote control
Old 11-14-2020, 05:16 PM
MBAtarga's Avatar
For $50 - this place will repair that control switch -
https://circuitboardmedics.com/hunter-fan-control-switch-98480x-repair/
Mark
'83 SC Targa - since 5/5/2001
Old 11-14-2020, 05:41 PM
Send a message via AIM to fintstone
You can buy a new one for about $20.
...or just remove it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-14-2020, 05:49 PM
Platinum Member
dad911's Avatar
Old light controllers don't like LED bulbs. They need higher current to work.
Edit: Apparently that was added to limit lights to 190 watts - thank the 2005/2009 energy code.
You probably don't need it.
Old 11-14-2020, 06:00 PM
Cool. Good to know that its not needed.
Old 11-14-2020, 08:34 PM
If you remove it, you should probably make a label of something to put inside the shade or somewhere discrete indicating that LE bulbs must be used (or a total of less than the 300W yours was rated at) for the next owner.
Old 11-14-2020, 08:52 PM
