ceiling fan wattage regulator?
Brain trust, I am sick and tired of the flickering lights in my kids study room. They almost never turn on the light, because they aren't old like me. They see like a cat.
What the heck if this regulator for? Its only hooked up to the lights but nothing to the fan motor? Is that what its celled, regulator? I have power going into it, but nothing coming out, so its deal. My thinking is, I will run two small LED lights into those sockets, the candle looking type bulb off the shelves. Why the heck do I need this dumb thing? What's it regulating? Lawyers want it on there to help my me to have a better, safer life? |
Lights should work fine with a rheostat. Motors not so much. They like stepped current (or voltage, not sure which). I can't help you much beyond that.
Is it for a remote control
For $50 - this place will repair that control switch -
https://circuitboardmedics.com/hunter-fan-control-switch-98480x-repair/
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
You can buy a new one for about $20.
...or just remove it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 11-14-2020 at 05:53 PM.. |
Platinum Member
Old light controllers don't like LED bulbs. They need higher current to work.
Edit: Apparently that was added to limit lights to 190 watts - thank the 2005/2009 energy code. You probably don't need it.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 11-14-2020 at 06:07 PM.. |
Cool. Good to know that its not needed.
If you remove it, you should probably make a label of something to put inside the shade or somewhere discrete indicating that LE bulbs must be used (or a total of less than the 300W yours was rated at) for the next owner.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
