power steering fluid vs Auto trans?
My kids 4 runner is finally complete. All suspension and rubber parts down below done. Tomorrow, 2 things need to be flushed, power steering and brake fluids. Stopped by Autozone today and found only 1 large bottle Perstone power steering fluid left. Went home to look at the manual and it calls for Dexron III. I was ready to buy 3 qts of Dexron but the dumb kid behind the counter talked me out of it and use Prestone. I know they may be the same fluid only Dexron has more detergent in it. Off the to the net I go and try and find an answer. It seems the Prestone fluid may dry out seals and cause leaking whereas tranny oil has chemicals within it that keeps seals from drying. Anyone know anything about this? Man, we need Mr. Lubbie back.
Old 12-05-2020, 11:19 PM
Personally, I would make damn sure I use the correct fluid in both of those systems, especially the transmission. And, I’m not a fan of the Prestone brand, in any shape or form.
Old 12-06-2020, 04:14 AM
LWJ LWJ is online now
The kid making minimum wage at AZ isn't a credible source. Buy the ATF.
My (non expert opinion) is power steering fluid is hydraulic fluid. ATF has a thicker viscosity and more lubricating properties.
Old 12-06-2020, 04:33 AM
Arizona_928's Avatar
Atf in the power steering.
One just can't mix the Atf and power steering fluid. That's a big no no.
dolor et pavor
Copyright
Old 12-06-2020, 04:48 AM
cashman's Avatar
FWIW, BMW E36 and E46 calls for ATF to be used in the power steering system.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 12-06-2020, 04:58 AM
Did you get the memo?
onewhippedpuppy's Avatar
Dextron for PS fluid is really common. I would just use what the manual says.
‘07 Mazda RX8-8
Old 12-06-2020, 06:34 AM
Read the owners manual.
Old 12-06-2020, 06:35 AM
Team California
speeder's Avatar
What they all said. This isn’t complicated.
Denis
Old 12-06-2020, 07:12 AM
Dextron for PS fluid is really common.....
Dexron is a lot more common.
1. If it says use Dexron III, use that. Period.
2. Find a new parts store.
Old 12-06-2020, 07:13 AM
Hell Belcho
Nostril Cheese's Avatar
Do not mix fluids. It WILL leak.
Lots of cars use Dex 3 for PS fluid.
Old 12-06-2020, 08:22 AM
Senior Member
Superman's Avatar
Factory specifications.
Mocha 1978 911SC. "Coco"
Old 12-06-2020, 08:35 AM
Edministrator
Steve Carlton's Avatar
https://www.youtube.com/watch?v=pbWWxGmbS9s
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 12-06-2020, 08:51 AM
Years back had my 92 T bird out to Gingerman Raceway. After 30 min my power steering was screaming so load I could hear it with a helmet on. Pitted and the pump was just about dry. Only had Mercon V in the trunk. There was a Ford rep there so I asked if it was OK to pour that in. His response ‘ better than any power steering fluid you can buy’. Using it ever since.
Rich
Old 12-06-2020, 10:31 AM
Or just don't listen to anything they tell you there.
Old 12-06-2020, 10:37 AM
Thanks. Get his ass out of bed now so we can flush it.
Old 12-06-2020, 10:41 AM
My spelling was closer than Prestone.
‘07 Mazda RX8-8
Old 12-06-2020, 02:24 PM
It was another beautiful socal day but I discovered Dexron doesn't taste very good. I hooked up a hose from the return line into the bucket. The clamp came loose and spray that dirty fluid all over the place. Dang, that's a lot of fluid circulating that system. Spend more time cleaning up then actually changing the fluids. Got it done and its nice, smooth, and quiet now.
Old 12-06-2020, 05:40 PM
