My other ride is a C-130J
RNajarian's Avatar
Anyone a Clock Aficionado Here?
Sometime when I was enjoying my Middle East Vacation my mom put a wind up wall clock in my house that chimed every half hour.
Recently it stopped keeping time. Wind it up and it keeps time for 15 minutes then stops. I removed the movement and replaced it with a quartz movement. The swap took only 15 minutes. . . and now the clock keeps time. The only difference is no more 1/2 hour chime, which I’m OK with.
The question is. . . does anyone know if this Korean made movement is worth repairing or is it scrap? The movement indicates no jewels and manufactured by Rollens company of Korea.
Here is a photo of the clock with the new quartz movement
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 04-18-2021, 12:38 PM
Those springs look jacked.
Please understand that I am a fool but loosen and rotate the nuts on the far end of the coil, let it find a more natural angle.
Movement on the right and chime on the left is what i see.
You were so close to keeping it.
Chris
the more i learn, the less i know
Old 04-18-2021, 01:04 PM
RNajarian's Avatar
Nuts on the far end of the coil?
Do you mean on the bottom?
Old 04-18-2021, 02:31 PM
Yes, but be careful, there is some tension on the right one.
I'm talking out my butt, but we both know i'm right.
Chris
Old 04-18-2021, 02:45 PM
RNajarian's Avatar
I loosened the nut facing the camera on bottom right. No difference, the coil is NOT moving. I’ll see if I can get some movement without releasing all that kinetic energy.
Old 04-18-2021, 02:54 PM
If you can't get the movement to work...call your local horologist.
About five years ago, my GF clock wouldn't keep running. Called the clock guy, he came out and removed the entire movement. Brought it back 3 days later and it's worked great since.
$150
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 04-18-2021, 02:59 PM
wdfifteen's Avatar
That would be so fun to dig into. Great photos BTW.
I had a Victrola that didn't work. It had similar springs. I talked to a guy who restores them. He said the most common problem is the springs wear out where they are attached. I took it apart and sure enough the spring was broken at the inner attachment.
Old 04-18-2021, 03:24 PM
I figure the right coil is the movement, the pendulum would need to swing to discharge.
Chris
Old 04-18-2021, 03:30 PM
Take off the regulator and unless it’s overwound it should free itself.
The regulator is the two prong bit that the pendulum rocks back and forth.
Old 04-18-2021, 05:05 PM
Clean all the bearing surfaces with a little alcohol and re oil with clock oil. Not much can go wrong with those movements, normally just dirt in the bearings causes drag and stops the regulator wheel from smoothly operating.
Google movement name and number and you will probably get more youtube info then you want.
Old 04-19-2021, 06:21 AM
My wife is nuts about antique clocks. We have over a dozen. She spends most of an hour every Saturday winding them and setting them and adjusting them. On Saturday at noon it sounds like a clock shop in the house. She has one small antique clock in our bedroom that when it runs I call it the Metronome. Tic tick tick tick at a very loud noise. I stop it before I go to bed. That one does not get to run at night. The rest I have learned to tun out and usually I have no memory of their chiming through the day. Sometime in the evening while we are watching TV 5 different clocks in the living room will all start gonging, chiming, dinging, donging, and ringing and we kust pause TV to wait for the clatter to stop.
She has a local clock repair guy on speed-dial and she has he come by here on occasion to play clock whisperer on persnickety clocks. I know to not touch them.
She never blinks when I buy tools, scissor lift, or a new set of tires or brake pads so it is a good trade off.
Old 04-19-2021, 06:32 AM
Zeke's Avatar
If it runs out of the case then it wasn't somehow 'timed' in the case. What that means is a perfectly even "tick — tock — tick — tock." You start with the movement level using, well, a level in both directions. To restore the timing, or beat, you gently bend the verge (the rod that holds the pendulum ass'y) until the pendulum swings exactly the same distance right and left.
It's tricky and I'm not a qualified clock repair guy but I've done enough cases for people that I managed to find out how to make sure the clock will work when it gets home.
On oiling: less than a drop on each pivot and bushing. Usually a needle is dipped into the clock oi; and a tiny amount deposited at the bushing in the little cup.
Old 04-19-2021, 07:05 AM
I bought this damaged box and non working clock at a garage sale for 5 bucks. It didn't look like this. I transferred the clock works from a plain Jane oldie I had, replaced missing inlayed pieces, replaced old velvet background with burl veneer, added finials, re-stained, re-laquered and added a crow
Old 04-19-2021, 07:20 AM
canna change law physics
red-beard's Avatar
One of my business partners is a mechanical machine affectionado. Clocks, wind up record players, edison tube playes, old music boxes (the big kind that play things that look like a big saw blade). When we have Zoom meetings and they run past noon, it gets loud.
James
Red-beard for President, 2020
Old 04-19-2021, 07:22 AM
RNajarian's Avatar
Currently the movement is in my garage mounted to a cabinet. I’ve got a pretty good 360 degree view of the movement. Outside the cabinet of the clock it runs the same as if it was inside the cabinet. It runs for 15 minutes then stops. Currently the pendulum is not attached.
One thing I should note. . . there may be a gear hanging up. Occasionally when I noticed the clock had stopped I would reset the time and there would be resistance to moving the minute hand, a POP then the hand would move freely. However this anomaly does not occur regularly.
Currently I am trying to get some tension out of the main spring. As you can see it is wound pretty tight. Hopefully that may make things a little clearer.
I’ll be honest, all that stored energy does scare me a little.
Old 04-19-2021, 07:24 AM
Zeke's Avatar
Tap the spring to free it up. It likely has some rust inside. Loosening the spring is covered a 1000 times on YouTube.
If there is rust it should come out.
Old 04-19-2021, 07:33 AM
The clock repair guy my wife uses is a meticulous clock geek that started as a hobby. On occasion we bring a clock back to him for a tune up and adjustment. I like to horrify him by saying I hosed it all down with WD-40 and now it does not work.
He has a well over 100 clocks in his shop. He is my wife's "crack dealer" for rare clocks.
Old 04-19-2021, 07:41 AM
When I was reading your previous post, I was thinking you needed a junk clock from a garage sale that you could disassemble on the dining table one day while the missus was gone. Then you make sure you've got a bunch of tools out and spread around, vise grips, hammers, screwdrivers, etc... for when she comes home.
Old 04-19-2021, 07:51 AM
RNajarian's Avatar
Some more photos, it looks like a small amount of tension has been relieved from the main spring.
Old 04-19-2021, 07:54 AM
It is like a stake through the heart when our clock guy sees an pretty antique case with some modern battery operated clock mechanism in it.
I can PM him you his contact info if you really want to talk to a pro. Likely it is not really worth the postage unless it is a rare brand and the parts are usable.
Our pro goes to clock conventions and buys and sells parts so the parts are not the rare. Especially with so many antique dealers gutting the movement and putting in battery operated movements.
Old 04-19-2021, 10:05 AM
