Hell Belcho
My father and I built a lot of custom homes in Beverly Hills, Bel Air, Malibu. We installed designer ice cube machines in some of them. They cost thousands of dollars. Amazing waste of money.
Saved by the buoyancy of citrus. |
The ice sphere above was made with this toy:
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
abides.
They work OK, but are kind of a hassle, IMO. Here's one example.
Graham 1984 Carrera Targa |
Platinum Member
Or cool the tip of your nose when tipped to drink?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Well - in my case, I was drinking scotch - so it cools it just bit as you sip - as well as adds a little water. With a regular cocktail that fills the glass - it would just serve as ice making it cold.
Platinum Member
As you can tell I'm not a scotch drinker..... I stand corrected. Thank you.
Counterclockwise?
Can you get pieces of ice berg?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I want some Ice 9.
Platinum Member
I think there was a place here in town that was using a jeweler's type wire saw to cut pieces of clear ice off of a large hunk. They made the big hunk over an 18-20 hour process, then cleaved off pieces as needed for drinks. Should you pay more for that pretty labor extensive process?
We just went to a local distillery after work, they had both crystal clear "ball ice" for low-ball glasses and "cylinder ice" for high-ball glasses, which is neat. Neat. Also how I drank my Rye, because I have hair on my chest and don't need shiny ice balls for my booze.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
