Just thinking out loud
On the beater it has been on for about 120K miles. I can't remember exactly what for, heated 02 or bad cat, something in that department. I don't give a rip and I'm sales rep for a company that sells both. I wear 2 hats when it comes to that light. No emission testing here.
83 944 91 FJ80 84 Ram Charger (now gone) |
Misunderstood User
I owned a 2003 VW Passat for 5 years - bought used and put 50K mikes on the car. The check engine light was on more than it was off. All emission related issues.
I was working in Mexico for a few weeks during this time period and most of the taxis were VWs. Every taxi I was in had the check engine light on. Must be common i said to myself.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Yep, I think my Boxster will have some of that.
Brew Master
I fixed my subie by putting a piece of black tape on the instrument panel where the CEL light is. Worked like a charm!
Nick |
I understand that I am weird, but every system, control or feature on my cars, work as designed from the factory, or even better.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
It'll be legen-waitforit
Instead of a cel they should use the $ as the indicator of how expensive it will be to fix, from: $ to $$$$$
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Had a 99 VW TDI. Took it to the dealer because the check engine light was on. Still under warranty it was. They kept it for a day and as I was driving it away the light came back on again. Had to leave it another day. That car would throw a CEL every week. Never another VW.
Platinum Member
Can't pass NJ inspection if check engine light is on. Junked a running VW Jetta because of that. New cats were more than it was worth.
I know people that also think the oil light means add oil, or get it changed.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Our car currently has the CEL. It is because it doesn't warm up fast enough so I have to change the thermostat.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
And the code will most likely go away as soon as the outside temps come back up .
No left turn un stoned |
I don't think so, it started 6 months ago. Thermostat is cheap though.
Lots of snow Porsche away
In my subie, I will worry when it shuts off. The jeep I expect to work as advertised day in day out so it I would have rectified.
But in the end, a CEL is never really a panic. Should be checked so you know why it popped, but even the lean codes pop to tell you that the car has experienced a lean bank and is needing to exceed the fuel schedule to correct it. A car smart enough to tell you it is lean is smart enough to correct it almost every time. The biggest impact to almost any CEL fault is most likely a small dip in mileage.
76 911S 86 GMC K1500 78 XS750 cafe racer to be 79 XS750 because one is just not enough |
^^^ Correct. There are other lights on the dash that are a lot more important to react to.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Driver
It's partly why I like my '87 911 better than my '90. Soon after I bought my 964, some rubber air shroud/duct just above the fan in the engine compartment disintegrated. Or rather popped while I was driving, as it's slightly positively pressured, I think. Somehow that set off the knock sensor, which tripped the CEL. Even after I replaced the part, the CEL remained lit. I had to get the CEL extinguished at my mechanic (thanks, TRE) because I don't have the Durametric to do that.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Most folks have some vehicles that are nothing more than an appliance to them, and are mostly considered consumable and disposable. Also, I wouldn't want to spend a ton of money to keep an econobox that's probably half plastic and engineered to be disposable in perfect shape. Many of us probably maintain some cars to a higher standard, but not all of them. Part of the deal is maybe that you've got great cars that are worth maintaining?
It's the same in TX (at least where I am). If you've got a 2007/8 vehicle w/OBDII then your inspection is good as long as the CEL is not on (and your car shows as "READY" via a scanner) and then they also usually check tires, bulbs and wipers.
Actually, I'll be that they get it fixed regardless. Glenn is not typical in that regard. He'll probably gripe about it and say that's why he prefers his cars.
The check engine light on my 2003 Tacoma was on for so long ( 5-6 years i'm guessing) that the bulb finally burned out.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Inspections?? In MI...if you have the money for the plate...you are good to go.
