Wave forms bouncing back etc. |
As others have said check that plug under load and see if the voltage stays up, the poor connection can also be where that plug is wired from, do you know where the wire feeding that plug starts. Do you have anything driven by a VFD on that circuit, like an exhaust fan or fridge?
I did have led lights in a nearby range hood fail around the same time' Hood on a different dedicated circuit, maybe transformer is somehow causing rf, but it must be in the line, as I had the thing 10 ft away and it malfunctioned. It worked fine on the troublesome outlet for two years prior. Have warranty parts coming for the hood, will install. But issue is there whether transformer energized in hood or not. |
Probably the fridge compressor motor, or the fridge controls. Some older motors have a capacitor, and some newer ones use inverter drives, both can cause noise in the AC line.
Just the compressor cycling on is likely create a low voltage dip on that circuit, possibly resetting the controller. |
The fridge is on the same circuit as the sous vide? If so, try the fridge on a different circuit with an extension cord and see if the sous vide works.
Refrigerators should be on a dedicated circuit, and are by code in new construction. |
You can rule out the fridge by using a heavy duty extension cord and plugging the fridge into a different circuit.
Greg, time to sell the house while the market is hot. ;)
Is the refrigerator an inverter type compressor?
No idea if this could contribute but merely curious. |
What's really got me stumped is that this all worked fine, fridge, sous vide, everything, for almost 3 years. |
Bit surprised nobody has yet suggested to check the ground on that socket
^^ post 20..... but current should not be travelling through the ground.
I still think it's a poor connection somewhere. Measure voltages under load, or see if a simple old-style incandescent light plugged into the same outlet flickers when running the sous vide. |
and some other appliance leaks. and affects this one or vice versa |
Does the device even have a ground pin? Have you re-tested your hypothesis? You could just have a flakey device.... |
Yes, I used a different brand immersion circ, brand new out of the box (initially thought mine was bad) and it behaves the same way on this outlet, but fine on the others. Tested for ground and load, didn't test for leakage to ground, will do that, but have swapped outlet with no effect. I see dead people.... |
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZSNyiSetZ8Y" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
| All times are GMT -8. The time now is 05:58 PM. |
