Very strange electrical issue, thoughts?
I cook sous vide using an anova immersion circulator, which has a built in pid temp control. When plugged into a specific outlet in my kitchen, the unit continues to heat beyond the setpoint. When plugged into any other outlet in the house, including outlets on the SAME circuit, it works fine. Tried another brand of cooker, does the same thing.
Electrician just left. All outlets on circuit appear normal, voltage good etc. Replaced the problematic one, and same problem... Ghost in the outlet?
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
No idea here why it would go above the set temp.
My Sous Vide Art has stopped a couple times when into an hour or more. I quickly learned that when the plastic container got warm enough, the clamp was slipping down..forcing water over the max fill line. Now, I wedge something under the top of the clamp to keep it from slipping.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Hell Belcho
Did you replace the outlet?
Saved by the buoyancy of citrus. |
The only thing I can come up with because I am no professional is that you have
a single phase 220 volt power source to the home and that is two 110 volt circuits. The one circuit of the two is has small voltage different than the other. It might mean the solid state voltage threshold of your appliance doesn't accept or work as designed because the voltage of circuit #1 isn't within the tolerance. Without knowing your internal house wiring 110 volt circuit distribution between the two 110 volt circuits that make up your load center, I would begin plugging it in in different rooms and maybe the other 110 volt circuit will accept the gizmo you are having trouble with.
67 396 corvette coupe. Sold 66 351 AC Cobra kit. Sold 99 996 man coupe 2001 911 Turbo man coupe |
Yes, swapped out the outlet.
Been here a while
that's nuts.
any chance the thing has bluetooth or wifi so it can connect to your phone? Any chance the ghost is actually in the wireless communication....try an extension cord and moving the unit elsewhere, to a spot near one of the outlets that works perfectly. wild-ass-guess for sure.
looking for 1972 911t motor XR584, S/N 6121622 |
Weird? Try another piece of appliance?
Historically speaking; do you know of anyone, a prankster perhaps, or even a fat person, has died in the kitchen. And maybe remained as a poltergeist.
Weird is right. I initially thought the cooker was bad, so I bought a different one from amazon, and it did exactly the same thing, and the kicker is that its got manual/wifi and the original one is manual/bluetooth.
I really think its your appliances and I think Bliculle is correct, it must be the bluetooth or wifi that's the cause. What the hell is bluetooth doing on a piece of appliance anyway?
Is it the outlet, or something near it?
If you set it in the same spot, but use an extension cord to run it from another outlet, do you have the issue? If you move it to another spot where it doesn't have a problem, but use an extension cord to plug it into the problem outlet, is there still a problem? |
Its kinda academic as I can use it on the good outlets and the electrician couldn't find anything that would burn the house down, but it stumps me.
If you decide it's the cooker....this is the one I have....works perfect, no bluetooth
https://www.amazon.com/Sous-Vide-Cooker-Immersion-Circulator/dp/B077GXV153/ref=sr_1_3?dchild=1&keywords=sous+vide+art&qid=1614898904&sr=8-3
I like rockfan's thinking, nature v nurture.
Chris the more i learn, the less i know |
Almost Banned Once
Have you verified the voltage of the problem outlet with a multi meter?
- Peter |
I reckon there is self-inflicted resonance circuit and that outlet just happens to have right wire length for that oscillation to occur. Chinesium parts are very bad when it comes to spreading interference back to network. There is probably chopper step-down circuit in the heater which is not damped by condensator (saves 50c) and that is feeding back. Oscilloscope should tell...
Thank you for your time, |
Platinum Member
Did electrician measure voltages under load (with it plugged in?) including the neutral? I suspect he just plugged in the simple tester.
If you have a voltmeter, measure voltage from hot-neutral and neutral to ground with the sous vide plugged in. Or plug a light into the same receptacle and see if it flickers when the sous vide is on. My money is on resistance (poor connection somewhere) in the neutral or ground lines.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
