greglepore's Avatar
Very strange electrical issue, thoughts?
I cook sous vide using an anova immersion circulator, which has a built in pid temp control. When plugged into a specific outlet in my kitchen, the unit continues to heat beyond the setpoint. When plugged into any other outlet in the house, including outlets on the SAME circuit, it works fine. Tried another brand of cooker, does the same thing.
Electrician just left. All outlets on circuit appear normal, voltage good etc. Replaced the problematic one, and same problem...
Ghost in the outlet?
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 03-04-2021, 11:31 AM
No idea here why it would go above the set temp.
My Sous Vide Art has stopped a couple times when into an hour or more.
I quickly learned that when the plastic container got warm enough, the clamp was slipping down..forcing water over the max fill line. Now, I wedge something under the top of the clamp to keep it from slipping.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-04-2021, 11:43 AM
Hell Belcho
Nostril Cheese's Avatar
Did you replace the outlet?
Old 03-04-2021, 11:47 AM
Rapewta's Avatar
The only thing I can come up with because I am no professional is that you have
a single phase 220 volt power source to the home and that is two 110 volt circuits.
The one circuit of the two is has small voltage different than the other.
It might mean the solid state voltage threshold of your appliance doesn't accept or work as designed because the voltage of circuit #1 isn't within the tolerance.
Without knowing your internal house wiring 110 volt circuit distribution between the two 110
volt circuits that make up your load center, I would begin plugging it in in different rooms and maybe the other 110 volt circuit will accept the gizmo you are having trouble with.
67 396 corvette coupe. Sold
66 351 AC Cobra kit. Sold
99 996 man coupe
2001 911 Turbo man coupe
Old 03-04-2021, 11:48 AM
greglepore's Avatar
Yes, swapped out the outlet.
Greg Lepore
85 Targa
Been here a while
that's nuts.
any chance the thing has bluetooth or wifi so it can connect to your phone? Any chance the ghost is actually in the wireless communication....try an extension cord and moving the unit elsewhere, to a spot near one of the outlets that works perfectly.
wild-ass-guess for sure.
looking for 1972 911t motor XR584, S/N 6121622
Old 03-04-2021, 11:59 AM
Weird? Try another piece of appliance?
Old 03-04-2021, 12:26 PM
Bill Douglas's Avatar
Historically speaking; do you know of anyone, a prankster perhaps, or even a fat person, has died in the kitchen. And maybe remained as a poltergeist.
Old 03-04-2021, 01:49 PM
98 Honda Prelude
22 Honda Civic SI
Old 03-04-2021, 02:01 PM
greglepore's Avatar
Weird is right. I initially thought the cooker was bad, so I bought a different one from amazon, and it did exactly the same thing, and the kicker is that its got manual/wifi and the original one is manual/bluetooth.
Greg Lepore
85 Targa
Old 03-04-2021, 02:17 PM
Man, that movie scared the living siht out of us for weeks. Sneaked out of the house, took the bus to Hollywood and caught a late show. Scared sihtless walking up our hill back home.
Old 03-04-2021, 02:22 PM
I really think its your appliances and I think Bliculle is correct, it must be the bluetooth or wifi that's the cause. What the hell is bluetooth doing on a piece of appliance anyway?
Old 03-04-2021, 02:24 PM
Is it the outlet, or something near it?
If you set it in the same spot, but use an extension cord to run it from another outlet, do you have the issue? If you move it to another spot where it doesn't have a problem, but use an extension cord to plug it into the problem outlet, is there still a problem?
Old 03-04-2021, 02:33 PM
greglepore's Avatar
Good question. I'll try that. I thought about rfi, but there's not a nearby source.One outlet that works is within 3 ft of the problem one.
Greg Lepore
85 Targa
Old 03-04-2021, 02:55 PM
greglepore's Avatar
Its there to allow remote start/stop and temp monitoring. If I change the temp on either unit via wireless, it changes the set temp on the display, but the unit still overruns it, but again, only on the problem outlet. And the unit recognizes the set temp, as it beeps as it should when it reaches it, but the heat stays on. Also, the temp reading on the unit is correct (actual temp, not the set temp) as I've checked that.
Its kinda academic as I can use it on the good outlets and the electrician couldn't find anything that would burn the house down, but it stumps me.
Greg Lepore
85 Targa
Old 03-04-2021, 02:58 PM
If you decide it's the cooker....this is the one I have....works perfect, no bluetooth
https://www.amazon.com/Sous-Vide-Cooker-Immersion-Circulator/dp/B077GXV153/ref=sr_1_3?dchild=1&keywords=sous+vide+art&qid=1614898904&sr=8-3
98 Honda Prelude
22 Honda Civic SI
Old 03-04-2021, 03:03 PM
I like rockfan's thinking, nature v nurture.
Chris
the more i learn, the less i know
Old 03-04-2021, 03:04 PM
Almost Banned Once
sc_rufctr's Avatar
Have you verified the voltage of the problem outlet with a multi meter?
- Peter
Old 03-04-2021, 05:20 PM
beepbeep's Avatar
I reckon there is self-inflicted resonance circuit and that outlet just happens to have right wire length for that oscillation to occur. Chinesium parts are very bad when it comes to spreading interference back to network. There is probably chopper step-down circuit in the heater which is not damped by condensator (saves 50c) and that is feeding back. Oscilloscope should tell...
Thank you for your time,
Old 03-04-2021, 11:46 PM
Platinum Member
dad911's Avatar
Did electrician measure voltages under load (with it plugged in?) including the neutral? I suspect he just plugged in the simple tester.
If you have a voltmeter, measure voltage from hot-neutral and neutral to ground with the sous vide plugged in. Or plug a light into the same receptacle and see if it flickers when the sous vide is on.
My money is on resistance (poor connection somewhere) in the neutral or ground lines.
Old 03-05-2021, 01:29 AM
