![]() Wave forms bouncing back etc. |
As others have said check that plug under load and see if the voltage stays up, the poor connection can also be where that plug is wired from, do you know where the wire feeding that plug starts. Do you have anything driven by a VFD on that circuit, like an exhaust fan or fridge?
87 930, Last edited by 908/930; 03-05-2021 at 03:11 PM.. |
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I did have led lights in a nearby range hood fail around the same time' Hood on a different dedicated circuit, maybe transformer is somehow causing rf, but it must be in the line, as I had the thing 10 ft away and it malfunctioned. It worked fine on the troublesome outlet for two years prior. Have warranty parts coming for the hood, will install. But issue is there whether transformer energized in hood or not.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Probably the fridge compressor motor, or the fridge controls. Some older motors have a capacitor, and some newer ones use inverter drives, both can cause noise in the AC line.
Just the compressor cycling on is likely create a low voltage dip on that circuit, possibly resetting the controller.
87 930, Last edited by 908/930; 03-05-2021 at 07:48 PM.. |
Platinum Member
The fridge is on the same circuit as the sous vide? If so, try the fridge on a different circuit with an extension cord and see if the sous vide works.
Refrigerators should be on a dedicated circuit, and are by code in new construction.
Its also on the same circuit as two other outlets that work with the sous vide, and one is closer.
Platinum Member
You can rule out the fridge by using a heavy duty extension cord and plugging the fridge into a different circuit.
I see you
Greg, time to sell the house while the market is hot.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Funny that you say that, we put an offer in on a place today...
UnRegistered User
Is the refrigerator an inverter type compressor?
No idea if this could contribute but merely curious.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
What's really got me stumped is that this all worked fine, fridge, sous vide, everything, for almost 3 years.
Gon fix it with me hammer
Bit surprised nobody has yet suggested to check the ground on that socket
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Platinum Member
^^ post 20..... but current should not be travelling through the ground.
I still think it's a poor connection somewhere. Measure voltages under load, or see if a simple old-style incandescent light plugged into the same outlet flickers when running the sous vide.
and some other appliance leaks. and affects this one or vice versa
Does the device even have a ground pin? Have you re-tested your hypothesis? You could just have a flakey device....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Yes, I used a different brand immersion circ, brand new out of the box (initially thought mine was bad) and it behaves the same way on this outlet, but fine on the others. Tested for ground and load, didn't test for leakage to ground, will do that, but have swapped outlet with no effect. I see dead people....
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 03-08-2021 at 02:57 PM.. |
